Custom turbo kit?
Old Mar 29, 2005 | 09:49 AM
ORcivicsi's Avatar
Default Custom turbo kit?
I have all the piping for my intercooler, but now i need the upper charge pipe. What did you do for your upper charge pipe? I am thinking about using my AEM CAI piping. Any other good suggestions?
Where can i get gaskets for my manifold to turbo and turbo to DP connections?
Thanks H-T for your help!
Old Mar 29, 2005 | 10:46 AM
93turbo16's Avatar
Default Re: Custom turbo kit? (ORcivicsi)
You can use any pipe you want that fits. Also how are we suppose to tell you where to get your gaskets if you didn't tell us what turbo you have or manifold. We aren't mind readers.
Old Mar 29, 2005 | 12:47 PM
oxSLEEPERxo's Avatar
Default Re: Custom turbo kit? (93turbo16)
if you use your aem cai, you need to cover it up or weld up that small hole on the pipe
Old Mar 29, 2005 | 12:52 PM
fresh pizza guy's Avatar
$4500 in a D series
Default Re: Custom turbo kit? (oxSLEEPERxo)
order some mandrel bent pipe from JC whitney and have your BOV flange welded onto it...
Old Mar 29, 2005 | 01:14 PM
ORcivicsi's Avatar
Sorry i have a shitbird manifold and a sc50 turbo
Old Mar 29, 2005 | 01:16 PM
mattEG's Avatar
To be honest I went to the local exhaust shop and picked up some mandrel bent tubing and then mocked up what I needed and clamped it from there.
As for your gaskets, you can make your own if you're so inclined. Gasket material = cheap.
Old Mar 29, 2005 | 05:10 PM
$4500 in a D series
Default Re: (mattEG)
the only problem with making your own gaskets is that they can blow out... if you dont torque all the bolts around the gasket perfectly it will fail after about a month... - happened to me with my turbo to my downpipe gasket... had to buy a metal one
Old Mar 29, 2005 | 09:23 PM
ORcivicsi's Avatar
Default Re: (fresh pizza guy)
where can i get the gaskets for an sc50?
Old Apr 3, 2005 | 06:02 PM
SL0WEGG's Avatar
Default Re: (ORcivicsi)
heres one gasket
turbo gasket
http://www.atpturbo.com/Mercha...e=BCS
Wastegate gasket
cant seem to find the one for the dp gasket. as for the upper charge pipe. i would just get a u bend. that should work. search NOOB!!!!
KeyserSoze
Welding / Fabrication
40
Nov 27, 2005 10:21 PM
ORcivicsi
Mar 16, 2005 09:12 PM
krazn
Jul 23, 2004 07:06 AM
MikeMAN
Feb 26, 2003 02:22 PM
