Custom D16z6 Turbo Setup Help!!!!!
Old Dec 6, 2001 | 10:34 AM
craz_e_99's Avatar
Default Custom D16z6 Turbo Setup Help!!!!!
ok...i have a d16z6 and a buddy of mine with a 3000 gt is offering me his two 9b turbos for free becuz he has upgraded 15G HKS turbos. my question is what all will i need to run this turbo safely...he says theyre good up to 9psi a piece....of course im only runnning one turbo and the other is for backup. i only plan to run maybe 6.5 psi daily, 8psi at the track. i dont wanna rebuild the bottom end or nothing. i know i need the manifold and downpipe, but what else. i just need the bare necessities to get it running. i also need to know where to purchase these needed items since im new to turboing civics. thanx
Old Dec 6, 2001 | 10:36 AM
craz_e_99's Avatar
Default Re: Custom D16z6 Turbo Setup Help!!!!! (craz_e_99)
oh yea...wat about fuel delivery for the posted psi's i plan to run also??
Old Dec 6, 2001 | 10:52 AM
VTC_CiViC's Avatar
Manifold, turbo, DP, oil feed line, oil return line with fitting for oil pan, new intake piping, some kind of fuel supply setup, check valves or Missing Link for MAP bypass. Exactly what kind of turbo's does Mitsu use on the VR-4's?
SiR Kid's Avatar
New User
Those stocker turbo's are WAY small for anything other than a go kart.
Old Dec 6, 2001 | 12:39 PM
craz_e_99's Avatar
Default Re: Custom D16z6 Turbo Setup Help!!!!! (VTC_CiViC)
well they use two TD04 "9b" turbos....but obviously i can only use one. they have a peak cfm rating of 265 per turbo. the guy i know said that they would max out at about 9psi per turbo. i only plan to boost 6.5psi daily and 8psi possibly at the track anyhow so that wouldnt really be a big deal topping out at 9psi. i wanted something similar to the greddy kit but cheaper, although i know they use a bigger turbo. i need more info on fuel delivery and where to buy manifolds and downpipes.
Old Dec 6, 2001 | 12:42 PM
craz_e_99's Avatar
also i would like to know that if i buy a manifold for the above turbo which has a td04 housing....will any other turbo compressor fit on it if i decide to upgrade?? this is really just a test project which i might be happy with or i might wanna upgrade when more money comes about...
Old Dec 7, 2001 | 03:28 PM
craz_e_99's Avatar
hello??????????
Old Dec 9, 2001 | 05:08 PM
craz_e_99's Avatar
Old Dec 11, 2001 | 11:30 AM
AshlandSi's Avatar
Those turbos are tiny.....definitely won't run out to 7200+rpm for a D16z6.
Old Dec 11, 2001 | 11:31 AM
AshlandSi's Avatar
Default Re: Custom D16z6 Turbo Setup Help!!!!! (AshlandSi)
The Greddy turbo is a TD04 as well, so the turbo you have may bolt up to a Greddy manifold. Can't verify this though, as Greddy may have their own flange bolt pattern.
Old Dec 11, 2001 | 12:40 PM
RGAZ's Avatar
New User
I agree, those 9bs are nasty small. If you want some custom info, take a look at the web page in my sig. It is for 88-91 CRXs D16A6, but might work on your setup. I would definitely not use that turbo though, it will make your car slower over 4000 rpm. The damn t25 I am running is too small and runs out of breath above 5500rpm, but damn she is fun as hell from 2500 to 5000!!
Good luck,
Randy
phaphon
Aug 7, 2012 09:10 AM
racinskittle
Jul 11, 2003 11:17 PM
Ragezero76
Jul 2, 2003 10:39 PM
ACURACY_VTEC
Aug 13, 2002 11:11 AM
