Curious about spool time
Old Feb 27, 2014 | 04:40 AM
89efhatchy's Avatar
Default Curious about spool time
I'm curious about other people's spool time on an s366. I feel like this things doing really well considering the motor. It's an 8.5:1 83mm b16, stock port head with itr cams, victor x, 2.5" ic piping besides the 3" cold side pipe. Using our twin scroll top mount. S366 .91ar, 4" downpipe. Just did some street pulls last night on e85 to get it ready for the dyno.
This was third gear.
Old Feb 27, 2014 | 04:57 AM
hondatech8798's Avatar
Default Re: Curious about spool time
Wow that's impressive!!!
In for dyno results!!!!!
Old Feb 27, 2014 | 07:24 AM
Muckman's Avatar
Moderator in Chief
When I increased compression ratio 4.5 points it didn't affect spool at all.
Old Feb 27, 2014 | 08:54 AM
89efhatchy's Avatar
I've heard compression doesn't affect spool much.
Old Feb 27, 2014 | 09:02 AM
TheShodan's Avatar
Moderator
Its recovery "spool" that is what the increased CR does, to help get to the effective compression faster in between gearin. On a one pull dyno, NO....
Old Feb 27, 2014 | 09:05 AM
Freemananana's Avatar
I retract my previous statements. I was incorrect. This is true. It doesn't affect spool much. It was something else.
I went back and found the thread I was thinking about.
Old Feb 27, 2014 | 11:15 AM
89efhatchy's Avatar
Thankfully turning 9500+, that's not a problem either.
Old Feb 27, 2014 | 11:49 AM
dcmatt's Avatar
You were on the 62 mm before right?
Old Feb 27, 2014 | 02:29 PM
89efhatchy's Avatar
I had an s360 before. 22#@4800 with it. Switch to e85, s366, and c02 time based controller. World of difference. The car barely spun street tires on 22# on the last setup. Took it out last night to do a few pulls to get it close before it goes on the dyno and was spinning 24.5s on the highway on 24#. Planning to turn it up to 30-35#.
airslammedcivic2
Apr 8, 2010 12:18 AM
b18sihatch
Dec 20, 2006 05:47 AM
Boostage
Apr 11, 2005 07:11 AM
11psiTurboSI
Jul 21, 2003 10:00 AM
LsTurbo91
Jun 19, 2002 03:19 PM
