CTR crank pulley / Stock Fuel Rail? ? ?
Will Ctr oem lightweight crank pulley be a problem with boost?
also when how much can a stock fuel rail on a b16 hold up?
Moderator
Re: CTR crank pulley / Stock Fuel Rail? ? ?
A lightweight crank pulley would not be a problem, but it won't benefit the system either. This isn't like a supercharger where any additional rotational inertia hurts the increase in power that you're making. (Check out that Holset turbo vid in the FAQs for reasons as to why that is.)
The stock fuel rail can hold quite a bit, over 400whp at least. The issue isn't the rail, it is the fuel injector you decide to use.
日本では、どこに住んでいるか。
日本では、どこに住んでいるか。
日本では、どこに住んでいるか。
日本では、どこに住んでいるか。
i have a fully built boosted GSR motor and im putting down 435hp and im using the stock pulley.im reving to 9000rpm,would you guys recommend i get a fluidampr or just stay with the stock one?
well then is there even a point to get a lighter crank pulley? i'm just concerned cuz i'm going to be reving very high on boost apps. also my stock cpulley has alot of chips in it. could cause inbalance no?
Seriously bud, throughout the year i heard numerous people destroying there motors by oil pump failures when using the ctr pulley. Balance your rotating assembly and atleast get the street pulley by either ATI, or fluidampnr. Cheap insurance for ya!
official honda whore
wow this is definately a 2 sided debate. problem is my crank pulley has alot of chips in it. most likely need to replace anyways, so i can go ctr, fluidampr, or ATI. damn it i need ppl with experience rather than opinions, opinions are still ok.
And despite what most people think B16b's DO NOT come with the N1 pulley, 95% of CTR's sold had AC and PS, there was a very small number of them dubbed "race base" that came without ac and ps, they also did not come with recaro's, the momo wheel, or power windows or locks, it was said this was a version for tuners since they would tear it all out any way. Furthermore the b16b crank is a good bit heavier than your average b16a or gsr crank, i am sure Honda designed it all to work properly, now taking that N1 pulley and putting it on a non b16b could be a problem...
[QUOTE=ntoxicatedtigah;37753399]problem is my crank pulley has alot of chips in it. QUOTE]
I have never used a honda crank pulley that wasnt chipped. And Ive never had a problem.
Ruiner
05-07-2002 10:28 AM
