ct26 boosted ls?
Old Sep 8, 2009 | 01:27 PM
LST Rex's Avatar
Default ct26 boosted ls?
hello all. Just got out of the supra game for a bit and picked up a b18a crx. My question is has anyone ever attempted this before? Im not very good at looking at compressor maps and comparing it to the b18a on where spool and efficiency would be.
Also if anyone has ever seen the space after a b series swap has been done, they too know that very little space is provided for a turbo up front. Who here can make a manifold to fit in a b series crx with a ct26 flange?
charlie
Old Sep 8, 2009 | 01:32 PM
irishflame27's Avatar
Default Re: ct26 boosted ls?
CT26's are very small even for a LS, i wouldnt bother with that turbo unless it was a 7mgte CT26, but even so, i would just use a nice garrett unit
Old Sep 8, 2009 | 01:37 PM
LST Rex's Avatar
actually the ct26 is right on point with a t3/t4 minus the top end. And it would be a ct26from a 7mgte. The mr2 and supra's turbo are the same with the exception of the mr2's being twin entry. I can pick up ct26's for very cheap even upgraded ones like 57trim and 60trim.
Was just pondering the idea since everyone is using t3/t4 turbos nowadays. I'd like to try soemthing different.
Old Sep 8, 2009 | 01:48 PM
even the upgraded ct26's are kinda a waste of time, i had a ct27 on my mr2 for awhile and it was boring so i went to a td06 20g instead, but if you have one and want to use it than anything is possible
Old Sep 8, 2009 | 01:49 PM
also is it a JDM or usdm turbo? the JDM have a cermanic wheel which doesnt take hi boost well and the usdm and wrc turbos are inconel
Old Sep 8, 2009 | 01:50 PM
LST Rex's Avatar
anyone of ht's sponsors make manifolds that will fit in the crx engine bay?
Old Sep 8, 2009 | 07:07 PM
desiromeo812's Avatar
talk to phil at spoolin performance.. he should be able to mock something up
91dxcrx
Aug 2, 2005 02:50 PM
egvtec
Feb 10, 2005 10:41 AM
crx90rcr
Sep 12, 2004 05:17 PM
Boostin95Teg
Sep 19, 2003 01:07 PM
