crx turbo help!
Old Jul 15, 2004 | 07:29 PM
spooned out's Avatar
Default crx turbo help!
friend has a 88 si B16A Greddy 18G trubo.... got the car to crank today and the rpm stayed at 4grand! not sure why hoses are routed like things...... wastegate/blowoff valve/boost gauge all "T" to the FPR and at idle vaccume is at 20psi...its not surging ... set-up is as follows
18G greddy trubo/manifold/downpipe
custom intercooler/piping
B&M fpr
RC 310cc saturated?
Apexi blowoff valve
my questions is...... since its a B16A and uses resistor box, i should not be using saturated injectors correct??? could this be the reason the rpm is staying at 4grand? we have prelude injectors and stock b16a injectors lying around should i use one of those and jack up the FPR?...... hopefully someone can shed some light into this... now as far as Fuel management what imputs do you have on this for temporary until more funds ...thanks in advance
Old Jul 15, 2004 | 07:34 PM
Mag00n's Avatar
Default Re: crx turbo help! (spooned out)
I believe a resistor box is used with peak and hold. Could be wrong. Also your idle sounds like a vacuum leak somewhere.
Old Jul 16, 2004 | 01:35 AM
SiR Kid's Avatar
New User
Default Re: crx turbo help! (SICKSOLVTEC-T)
Sounds like what happened when my brake booster vacuum line came loose...
Check it out. That's a BIG vacuum leak.
Old Jul 16, 2004 | 12:35 PM
Default Re: crx turbo help! (SiR Kid)
do you think a vaccume leak will cause it to go to 4g at idle? We thought the sautrated RC's are conflicting with the resistor box so were throwing back the stock injectors maybe the prelude ones .... any more ideas? if i'm getting a vaccume leak would the boost gauge still be reading 20psi vaccum?
A BOOSTED CRX
Mar 4, 2008 02:12 PM
spooned out
Sep 15, 2003 09:12 AM
spooned out
Sep 6, 2003 07:41 PM
spooned out
Jun 27, 2003 12:23 PM
CRX-Freak
Mar 3, 2003 08:34 PM
