B16A boost in work
Old Jun 26, 2003 | 11:12 PM
spooned out's Avatar
Default B16A boost in work
i have a stock B16A sirII in a 95 si.... i got a greddy 18G kit for a good price with out the injectors... Questions, can i run at low psi with stock injectors? I also have prelude injectors but no resistor pack will i need a resistor pack if i have the blue box? How safe is it to boost a stock b16A let say 5-8 psi daily? Plus i allready have a custom IC ..
another question... Trying to locate a knocking sound from the engine, i can't hear it when im in the engine compartment but when im sitting in the car i can hear a knocking sound not loud but enuff for me to hear it, sounds sorta like someone knocking on wood continuosly but when i give it some gas i can't hear it unless its at idle ....anyone?
Old Jun 27, 2003 | 12:49 AM
pissedoffsol's Avatar
25 Year Member
Default Re: B16A boost in work (spooned out)
what year prelude injectors? some are peak/hold, and some are saturated.
blue box = fmu. its not a rsistor box.
5-8daily is fine if you tune it well.
Old Jun 27, 2003 | 12:09 PM
thanks man .... i was told the prelude injectors were from a 95-96 models not the newer models...
Old Jun 27, 2003 | 12:23 PM
oyeah since the blue box was designed for 310cc injectors can i still use 440cc instead? i plan on up grading to t3/t4 down the line, just trying out this route first (beginners), but don't want to have to change whole setup, only manifold,turbo,downpipe,hondata & misc .... i allready have a vortec FMU should i use that instead of the blue box?
TylerC161
Sep 18, 2006 07:25 PM
D-meet07
Aug 26, 2005 04:25 AM
caliprelude3087
Sep 6, 2004 05:39 PM
boostincoupe
Jun 17, 2003 12:10 PM
SamB16
Jan 31, 2002 04:35 AM
