CRX intercooler pipe
Old Dec 4, 2003 | 08:12 AM
  #26
nevin's Avatar
Default Re: CRX intercooler pipe (MrCrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MrCrx &raquo;</TD></TR><TR><TD CLASS="quote">
thats how mine is setup also. The only other way I have seen is in here http://www.imagestation.com/album/?id=4291693501
Old Dec 5, 2003 | 09:23 AM
  #27
soundman's Avatar
I found some strong hose, it was almost like a shop vac. hose... It was good to 30psi, and I could wrap it around the bottom with no clearance problems, but it doesn't take heat real well, so it isn't the best solution.
Old Dec 5, 2003 | 09:32 AM
  #28
kid-honda's Avatar
Default Re: (iwouldHITit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwouldHITit &raquo;</TD></TR><TR><TD CLASS="quote">
so going this way is probably the best way? what about going from under like how some EGs and tegs go?or will it stick out to much?</TD></TR></TABLE>
Through the resivor hole is probly the best and most common way of doing it.
Old Dec 5, 2003 | 10:37 AM
  #29
D A 9's Avatar
Default Re: CRX intercooler pipe (Hayasa15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">has anybody ever tried cutting a hole thru the frame and running the piping through the hole?</TD></TR></TABLE>
I did that, it seemed to be the only way for me, I didn't want a smaller radiator like a lot of people do. I drilled the hole and put that stuff that you cover up the corners of the doors, that round black rubber/plastic stuff form PepBoys
it's not a CRX, but it's very close!
Old Dec 16, 2003 | 06:30 PM
  #30
Hayasa15's Avatar
Default Re: CRX intercooler pipe (D A 9)
thats what i was talking about. what if you weld in, say a 2.75 pipe into the hole that was cut in the frame and run a 2.25 intercooler pipe through it? then i dont think it would be dangerous to the structural integrity of the car.
Old Dec 16, 2003 | 06:35 PM
  #31
Hoosier Daddy's Avatar
I'm pretty sure there's a hole right where the horn is mounted, stock. You can go through there if you remove the horn.
Old Dec 20, 2003 | 07:28 PM
  #32
kid-honda's Avatar
Their is no hole behind the horns but it is a real good spot to cut a hole.
Old Dec 21, 2003 | 05:50 PM
  #33
r7's Avatar
r7
i used the maxrev manifold, jimfab bar, and lots of custom piping. =o 88 crx.
Old Dec 21, 2003 | 10:44 PM
  #34
Blackack26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hayasa15 &raquo;</TD></TR><TR><TD CLASS="quote">thats what i was talking about. what if you weld in, say a 2.75 pipe into the hole that was cut in the frame and run a 2.25 intercooler pipe through it? then i dont think it would be dangerous to the structural integrity of the car.</TD></TR></TABLE>
This is my plan on my DA
Old Mar 10, 2004 | 12:58 PM
  #35
Another B16's Avatar
New User
I cut the hole you are talking about and ran my exhaust through it with a supertrap. No problems at all. I don't have to worry about emissions so my exhaust is 14" long total.
Old Mar 10, 2004 | 06:20 PM
  #36
The Destroyer's Avatar
Default Re: CRX intercooler pipe (Another B16)
Where did you guys get your ic piping?
clemsonteg
Jun 1, 2006 07:16 AM
otto
Aug 31, 2005 07:22 PM
RACEPAK
Jul 24, 2004 12:30 PM
RedTegLS
Oct 14, 2003 04:12 PM
JrCRXHF
Jul 19, 2003 08:28 PM
