Integra intercooler piping question..
hey guys iam adding a turbo kit on my car and i wanted to know if anyone knows the dimension of intercooler piping i need, like 45 degree curves, 90 etc, straight pipe, please and thanks for the info
Re: Integra intercooler piping question..
what year teg is it? did i miss that?
your pipin should be 2.5" depending on yur power goals. as for the pippin curves and etc. are u keepin AC? what type of mani is it? oh nvm here just go to this link.
http://www.beesandgoats.com/boostfaq/g2icturbo.html
How is 3in piping not all the rage yet? Sure its a tighter fit and costs a little more, but it has less pressure drop across the piping system. Larger pipe will make your turbo work less to make the same flow, it will just be at less psi.
Takes about .035 seconds to fill a 3in pipe to 15psi than 2in. Huge 8ft piping will come out to .28 seconds. You are not going to feel that.
For my g3 teg I used 2.5 on the hot side because the turbo outlet was 2. Cold side was 3in.
4 180's
2-3 straights
All from Kteller
4 180's
2-3 straights
All from Kteller
1 Post
4 180's
2-3 straights
All from Kteller
4 180's
2-3 straights
All from Kteller
platinum00
01-20-2006 11:28 AM
