crappy dyno results
Old 01-11-2007, 04:12 PM
italstallion's Avatar
Default crappy dyno results
hey guys i just brought my car to the dyno today and im very dissapointed with the results the setup is
d16z6 stock motor with compression at 172 on each cylinder
garret t25 at 9 psi
2.5 IC piping
2.5 inch DP
2.5 inch mandrel bent s.s exhaust with a cat.
dsm 450's
tuned with cromepro by a very good local tuner the afr's are all around 12:1
on the dyno it made 135whp and 153lbs of torque ......the dyno it was on was a dynojet. So my question is why is it that most other people who have the same setup as me get around 190 whp and like 175 lbs torque???
Old 01-11-2007, 04:24 PM
boosted_dc2's Avatar
Default Re: crappy dyno results (italstallion)
why are you running a cat? just curious. do you have your maps that you can upload. also what kind of timing?
Landon
Old 01-11-2007, 04:26 PM
Default Re: crappy dyno results (boosted_dc2)
you have more torque than horsepower, thats cool.
Landon
Old 01-11-2007, 04:34 PM
ludesleep's Avatar
thats not cool...any motor that makes more torque than power is a turd!...especially if it wasnt built to pull things...
Old 01-11-2007, 04:39 PM
93turbo16's Avatar
Are you sure the timing is correct.. meaning the actual engine timing.
Old 01-11-2007, 04:43 PM
Default Re: (93turbo16)
yeah im running a cat because its illegal to not run one in canada and plus i dont want my car smelling like rotten eggs. also the turbo is pretty junk could that be the reason.
Old 01-11-2007, 04:53 PM
Default Re: (italstallion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by italstallion &raquo;</TD></TR><TR><TD CLASS="quote">yeah im running a cat because its illegal to not run one in canada and plus i dont want my car smelling like rotten eggs. also the turbo is pretty junk could that be the reason.</TD></TR></TABLE>
i hope your kiding.
Landon
Old 01-11-2007, 04:54 PM
Default Re: crappy dyno results (ludesleep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote">thats not cool...any motor that makes more torque than power is a turd!...especially if it wasnt built to pull things...</TD></TR></TABLE>
so a 4G63 is a turd?
Landon
umm no why would i be kidding
Old 01-11-2007, 04:59 PM
jfoster's Avatar
we'll need some more specifics .... like your timing and posting a graph would help.
Old 01-11-2007, 05:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by italstallion &raquo;</TD></TR><TR><TD CLASS="quote">umm no why would i be kidding</TD></TR></TABLE>
well a crappy turbo would probably have EVERYTHING to do with it depending on whats wrong with it.
by running a cat you are limiting your potential quite a bit. also without seeing your tune its hard to say if its mechanical or the tune.
Landon
Old 01-11-2007, 05:07 PM
yea the turbo has a quite a bit of shaftplay and also it drops to 5 psi at redline.i think its probably the turbo....ill try and get the map to post them too
sbiggi's Avatar
a bad cat smells like rotten eggs. No cat smells like ... strong exhaust
Old 01-11-2007, 05:15 PM
wow i never knew that...... i thought that having no cat would make it smell like rotten eggs.
Old 01-11-2007, 05:17 PM
ludesleep's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
Landon</TD></TR></TABLE> if it makes more torque than power then yes.
Old 01-11-2007, 05:22 PM
willyboyK20's Avatar
I just had my y8 dynoed
159 whp and 142 wtq
I tuned it on cromepro also
t3/t4 50trim a/r .48 @ 5psi
2.5 inch downpipe
2.5 inch cat
2.25 exhaust
here is the graph
Old 01-11-2007, 05:31 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesleep &raquo;</TD></TR><TR><TD CLASS="quote"> if it makes more torque than power then yes. </TD></TR></TABLE>
pure ignorance
Landon
Old 01-11-2007, 05:53 PM
Lightweight Boost's Avatar
turn it up . willieboy . i feel with another 3 -4 lbs adn a little more timing you could be pushing 185-200. running a bit rich around 3000-3500. pull a little fuel out there . remember lean is mean
Old 01-11-2007, 06:51 PM
igo4bmx's Avatar
post your power to speed datalogs.
make sure its not a slipping clutch
Old 01-11-2007, 07:30 PM
Bailhatch's Avatar
Default Re: (igo4bmx)
if you make more tq than hp either your turbo is small and/or your motors VE is at a low rpm. Ill tell you one thing, it's no fun with short gearing (Z6,b16,gsr,itr trannys) except for auto-x. Im all set with making good tq at low rpms on a front drive car. I like traction, it makes me go fast.
id say this turbo is blown or there is another problem. If the cat is in good shape it's not that. you can make well over 300whp with a 2.5" cat.
Old 01-11-2007, 07:41 PM
miro_gt's Avatar
Default Re: (Bailhatch)
it's a WG / exhaust related problem, as I told you over .turbod16.com
Old 01-11-2007, 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">if you make more tq than hp either your turbo is small and/or your motors VE is at a low rpm. Ill tell you one thing, it's no fun with short gearing (Z6,b16,gsr,itr trannys) except for auto-x. Im all set with making good tq at low rpms on a front drive car. I like traction, it makes me go fast.
hey whats up bail!!
i think hes running a stock cat.
Landon
Old 01-11-2007, 10:22 PM
khmboostedeh2's Avatar
Default Re: (miro_gt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miro_gt &raquo;</TD></TR><TR><TD CLASS="quote">it's a WG / exhaust related problem, as I told you over .turbod16.com</TD></TR></TABLE>
Id agree with exhaust, but not so much wastegate. If your boost guage is going to 9psi, but the motor is not producing any power I can foresee two possible problems. Either something is choking up your motor where air is flowing fine into the motor but not out, or timing is extremely far off. Nonetheless, Im no pro, and without any fuel/timing graphs & dyno sheets my guess is as useful as any others.
Old 01-11-2007, 11:30 PM
Ckjeepin's Avatar
So i guess my srt4 is a turd..
It only made 385whp. 450+tq
And my evo must be a turd too
320hp and 340tq
Old 01-11-2007, 11:32 PM
CRXdan's Avatar
Default Re: (khmboostedeh2)
if the boost is dropping off to 5 psi at redline theres your problem. you knew the answer to your question all along.
Rebuild or replace the turbo. Try a 14b this time, much better results.
Quick Reply: crappy dyno results
