Is this crankshaft useable
Old Dec 21, 2008 | 10:37 PM
katoeh2o's Avatar
Default Is this crankshaft useable
there appears to be a bad groove where that crankshaft seal would be. that may cause it to leak. I'm not sure so I thought I would ask you you guys with some engine building experience.
Old Dec 21, 2008 | 10:42 PM
ABK's Avatar
ABK
Default Re: Is this crankshaft useable
looks very dirty, hard to tell. clean it off with something, oil it up. Looks like the front main seal dug a groove into it. Was is in the boosted motor wihout upgraded pcv system? As long as there is no main/rod journal damage I would just get it cleaned and micropolished and use it. Make sure you offset the main seals so they don't sit in the grooves otherwise you might have some oil leak problems.
I had couple cranks do that, no problems with leaks. Just depends how bad the groove is, hard to tell.
Old Dec 21, 2008 | 10:43 PM
AR Performance's Avatar
how deep is it
Old Dec 21, 2008 | 10:52 PM
katoeh2o's Avatar
Originally Posted by AR Performance
how deep is it
I can just barley catch my finger nail on it. There is an Identical groove on the other end where the rear main seal goes.
Old Dec 21, 2008 | 11:12 PM
he a machine shop polish it and you will be good
Old Dec 22, 2008 | 12:08 AM
ABK's Avatar
ABK
yep
Old Dec 22, 2008 | 04:11 AM
reboosted's Avatar
they make a micro sleeve that fits over that if its to deep, ask a machine shop
Old Dec 22, 2008 | 04:36 AM
kornerk12's Avatar
You mean just polish the mains and rod journals right ?
EG-SIXV-TEC
May 2, 2012 06:28 AM
Skitso's CB7
May 5, 2011 10:22 PM
Jason P
Oct 4, 2010 11:06 PM
dth0ng69
30
Oct 8, 2009 03:29 PM
96b18c
Jan 24, 2002 06:27 AM
