Which Crank w/Which Block To Sleeve
Old Mar 3, 2005 | 11:38 AM
aalb1's Avatar
Default Which Crank w/Which Block To Sleeve
Currently I have a 2000 SI and I am looking to buy a block to sleeve since I can't afford the downtime of sleeving my original b16.
What I wanted to know is if I use a b18 block are there differences between the blocks that won't make the b16 head a direct bolt on? What about dropping the block in the engine bay with wiring, mounts, etc?
Also which crank should I use? If I get a b16 should I just stay with a b16 crank? If I get a LS Block should I stick with an LS crank? Same with a GSR Block and crank. Or if I frankenstein it, what will it look like with boost?
Old Mar 4, 2005 | 08:41 AM
aalb1's Avatar
Default Re: Which Crank w/Which Block To Sleeve (aalb1)
ttt
vtec8200
11
Jun 13, 2011 10:04 AM
hondacivic0909
12
May 6, 2007 01:49 PM
TedR719
Jul 28, 2002 02:05 AM
g2teg
Apr 8, 2002 03:38 PM
B20LS-T
Dec 6, 2001 07:41 PM
