Crank Fluctuation Question
Old Nov 1, 2005 | 04:08 AM
1FastCoupe's Avatar
Default Crank Fluctuation Question
Im planning on running a High boost application and the motor im using is a 94 GSR motor which came with a 3 wire crank fluctuation sensor and the wire harness I have is a 2000 SI which the plug for the CFS is a 2 wire. Should I leave it unplugged considering
Im using a p28 with Hondata and I dont think OBD1 looks for this sensor(correct me if im wrong). Is there a way to hard wire this in to make it work considering the plugs don't match up? I was going to buy the type R CFS which is 2 wire but its $120 at the dealer and Im not sure if I really need it. Im trying to get this car back together so any help is appreciated...
Old Nov 1, 2005 | 04:40 AM
kylemarhx's Avatar
you're right, the obd1 ecu won't look for the sensor. so even if you were to wire it in, it still would not be functional. don't worry about it.
Old Nov 1, 2005 | 09:45 AM
1FastCoupe's Avatar
Thats the answer I was looking for, Thanks
Old Nov 1, 2005 | 01:06 PM
TheThiefTheKnife'NTheGun's Avatar
Default Re: (1FastCoupe)
just did the exact same swap.. No need for the sensor
jonathan13
Apr 10, 2009 08:24 PM
ShawnR
Dec 29, 2005 02:33 PM
DaCRXboi
Aug 20, 2005 10:40 PM
IDriveHonda
Oct 13, 2003 03:37 PM
