cracked tip on injectors
Old Feb 21, 2003 | 03:59 PM
madman604's Avatar
Default cracked tip on injectors
on my OEM injectors, i cracked that see thru coving around the nozzle end. Can this be fixed? will there be a problem if i remove the rest of it? can i Epoxy it?
the second from the left.
Old Feb 21, 2003 | 04:17 PM
red_sir's Avatar
Default Re: cracked tip on injectors (Turbo E)
That's the pintle cap. It'll be ok if it doesn't look like it's gonna fall off. If it is, then you can just take it off too, but it won't affect the spray. It's just to protect the pintle inside.
Old Feb 21, 2003 | 04:27 PM
inspyral's Avatar
Default Re: cracked tip on injectors (red_sir)
I think when you send injectors to get cleaned, they usually replace all the o-rings, seals, grommets, and they also replace the pintle caps.
Old Feb 21, 2003 | 05:46 PM
Hybrid's Avatar
Default Re: cracked tip on injectors (inspyral)
Well I'm sending mine of to get done and yes they replace all the above, just make sure you request it to confirm.
Old Feb 24, 2003 | 06:58 PM
madman604's Avatar
Default Re: cracked tip on injectors (Hybrid)
where can i get the caps? honda dealer?
Old Feb 24, 2003 | 07:27 PM
shortyz's Avatar
turbo E if it aint falling off then just leave it. itll be fine
Old Feb 24, 2003 | 09:57 PM
Lei Siew Long's Avatar
Default Re: cracked tip on injectors (shortyz)
i don't think it's a good idea to leave it that way. with fuel pressure or an increase in fuel pressure, eventually, it'll crack all the way. and you'll run into the danger of not only leaning out, but, having your car catch on fire
Old Feb 24, 2003 | 11:34 PM
TurbothisLS's Avatar
no epoxy man
just go get those pintle caps replaced
they are cheap to replace
Old Feb 25, 2003 | 08:15 AM
madman604's Avatar
Default Re: cracked tip on injectors (TurbothisLS)
Im mostly concerned about the pieces of crap falling into my cylinders and holding a valve open or crunching in my turbo
yes its starting to fall off, so I can just remove or replace it, correct?
Powered By Garrett
Jun 21, 2008 03:10 PM
Chris1091
Sep 17, 2003 03:07 PM
Leb_CRX
May 23, 2003 06:17 PM
