CP piston question.
Old Nov 3, 2012 | 02:25 PM
boostontheD's Avatar
Default CP piston question.
building a motor and been looking for pistons
def only getting CP's
found some for a b16 for great price.
only question is will they work on GSR rods?
they are carrillo rods for GSR. im asking because i cant find a answer online about aftermarket pistons. found that stock b16 pistons need modified for stock gsr rods but i cant find anything about aftermarket ones.
any help would be awesome. id think that they should work but il ask before i waste some money
Old Nov 3, 2012 | 03:00 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: CP piston question.
Yes, they will work.
Old Nov 3, 2012 | 03:19 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
How many different rod companies are there?
Not to get off topic but I never heard of that company until today
Old Nov 3, 2012 | 03:21 PM
carrillo is part of CP if im not mistaken. with the CARR rod bolts they are rated 1000+WHP
Old Nov 3, 2012 | 03:35 PM
doood's Avatar
been there done that
really? carrillo is good stuff.
Old Nov 4, 2012 | 01:14 AM
rich7777's Avatar
They make "real" rods. They're not your avarage ching-chong-chow rod that uses cheap nasty steel.
Old Nov 4, 2012 | 03:28 PM
turbohatch96y7's Avatar
Now that's just racist "dawg"
Old Nov 4, 2012 | 05:54 PM
jojeezek's Avatar
lol
jojeezek's Avatar
i herd CP pistons top edge tends to break?
Old Nov 4, 2012 | 07:20 PM
DO IT ON ALL FOURS
I know for a FACT they at least used to...
Old Nov 4, 2012 | 11:09 PM
rich7777's Avatar
Lol, it wasn't ment in a racist way. I have a few Chinese friends personally "dog" (just to clear that one up).
Old Nov 5, 2012 | 04:16 PM
fukenboostin's Avatar
yup, had a fresh 83mm build, broke 2 right around the intake valve reliefs
Old Nov 5, 2012 | 04:46 PM
Muckman's Avatar
Moderator in Chief
Same here, same problem in 2005.
Has CP revised their design yet?
Old Nov 6, 2012 | 06:35 PM
zebiraross's Avatar
Cp pistons are made by Carrillo.
Old Nov 7, 2012 | 03:10 AM
blackeg's Avatar
I think they fixed the problem. I've been using cp since 08 and not had any chipping near the valve reliefs. I even overheated a motor bad enoug to have serious ptw contact on the dyno and the valve reliefs were just fine.
Carillo is part of cp and manley if im. Not mistaken. Good parts
If u are real worried you can ffile down any sharp edges which tend to collect heat
Old Nov 7, 2012 | 03:47 AM
Kr4nG's Avatar
does anyone know if the c clip on the piston matters where the open part is facing? if it suppose to have the open end up or down or left or right.
and yes cp pistons redesigned their piston since they had cracking problems. they are a lot better now.
Old Nov 7, 2012 | 06:20 AM
DO IT ON ALL FOURS
Once scorn, they are considered junk to me forever!!!
The C-clip opening should be 180* away from the notch, or at least as close as you can get it that way.
Old Nov 7, 2012 | 07:23 PM
West Werks's Avatar
Incorrect, CP (Calvert Pankl) bought out Carrillo a few years back. All parts are manufactured in CP's Irvine, CA facility now.
Old Nov 8, 2012 | 02:30 PM
Kr4nG's Avatar
does anyone have a pic of the correct way to put the c clip??
Old Nov 8, 2012 | 04:45 PM
DO IT ON ALL FOURS
Wow, are you joking? Put the damn opening the opposite side of the notch. It is that simple... If you need a picture then take it to a shop. Round ring goes into round hole.
Old Nov 8, 2012 | 05:01 PM
West Werks's Avatar
Thanks, I now need a new keyboard from the Stone IPA I just spit everywhere...
JDMstormtrooper
Mar 1, 2012 07:14 PM
stivic
May 20, 2007 05:26 AM
krazydbiker
Mar 24, 2007 02:24 PM
vtecn8ive
Dec 2, 2004 09:26 PM
NSTY Z33
Aug 20, 2004 10:36 PM
