B16 rod question
Old May 19, 2007 | 08:32 AM
stivic's Avatar
Default B16 rod question
With a B16 block using the ITR pistons what rods will work?? Lookin to get 11:5:1 comp just wondering if stock rods will hold up or do I have to get eagle or another aftermarket brand.
Old May 19, 2007 | 08:39 PM
stivic's Avatar
Default Re: B16 rod question (stivic)
Anyone??
Old May 20, 2007 | 05:23 AM
gibsanez's Avatar
You can't use an aftermarket forged rod with a stock cast piston, they use different styles of wrist pins.
Stock rods will hold up. You could upgrade rod bolts if you wanted.
Old May 20, 2007 | 05:26 AM
NJIN BUILDR's Avatar
The ITR pistons will give you less than stock compression (about 10:1).The CTR pistons will give you just less than 12:1.The stock rods are fine for NA street cars.JE (as well as other aftermarket companys) makes a 11.5:1 pistons.The part number for the JEs is 224229 for stock 81mm pistons.
JDMstormtrooper
Mar 1, 2012 07:14 PM
model x
Dec 5, 2005 06:45 PM
Mr. Vapor
Aug 31, 2005 12:20 PM
vtecn8ive
Dec 2, 2004 09:26 PM
blazin
Oct 10, 2002 01:33 PM
