couple problems with my fuel pump help
Old Dec 5, 2006 | 09:51 AM
exotik4doorcivic's Avatar
Default couple problems with my fuel pump help
i have a d16z6 with a a 14b turbo full msd ignition
dsm 450 cc injectors tuned on chrome pro at 9 lbs
now i heard that your stock fuel pump can handle up to 200 whp
im having problems with hesitation on the top end,
normally the car runs strong, pulls strong,i but sometimes (about once every couple weeks) the car will start to hesitate and or feel slower in the top end as if the car is starving of fuel, and when i shut my car off the car wont start and i have to pull out the back seat and bang on the fuel pump,
ive changed the fuel pump with a friends and still does the same thing
any help is appreciated
Old Dec 5, 2006 | 09:54 AM
s2kdre's Avatar
Default Re: couple problems with my fuel pump help (exotik4doorcivic)
its possible, just get a walbro 255, u cant go wrong for a 100bucks.
AbitAvenger's Avatar
ive got a d16z6 with a 14b @ 11lbs with 450cc injectors and I had to upgrade my pump to a walbro 255, its only 100 bucks man
Old Dec 5, 2006 | 09:58 AM
Default Re: (AbitAvenger)
you said you had to upgrade?? were you having the same problem as me??
also if i change the pump will it have to be tuned knowing it has a bigger pump??
Old Dec 5, 2006 | 10:09 AM
slow poke's Avatar
Default Re: (exotik4doorcivic)
It should be re-tuned yes and if your running a larger injector, then you always need to upgraded your pump!
IceySC
Dec 26, 2009 04:40 PM
Vegas H22Prelude Si
Oct 13, 2008 08:10 AM
peaNUTS6
Honda Civic (2001 - 2005)
Apr 2, 2007 11:30 AM
JeremyL
13
Sep 18, 2006 06:33 PM
Screamer
Jun 18, 2003 09:17 AM
