Could this be what is causing my overheating?
Old Mar 17, 2008 | 08:44 PM
Urugly's Avatar
Default Could this be what is causing my overheating?
So I have been battling overheating for too long and now that the nice weather is here I had to figure out what the hell is causing my overheatinng.
So TECH III pulled my head and found a hairline crack on one of the valve guides (think that is what he said).
The head gasket they said looked good and compression good before taking head off was good across the board too.
Is this why it was overheating at boost and not at idle? It was after 15 mins. of driving around street is when it would overheat and I would have to turn my heater on just to bring temps. back down.
Old Mar 18, 2008 | 04:58 AM
batboyvaj's Avatar
I don't think that would cause an overheat. make sure your fan is turning on and pointed in the right direction.
Old Mar 18, 2008 | 05:43 AM
tegman23's Avatar
same here i couldnt see why a valve guide would cause overheating, the headgasket blocks off any colant going to the head...vavle guides could cause smoking but not over heating...some one correct me if im wrong though
Old Mar 18, 2008 | 06:06 AM
Joseph Davis's Avatar
Default Re: (batboyvaj)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboyvaj &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that would cause an overheat. make sure your fan is turning on and pointed in the right direction.</TD></TR></TABLE>
+1
Could also be a thermostat stuck very slightly open; enough to cool at idle but not under (thermal) load.
Old Mar 22, 2008 | 02:43 AM
tekturbo's Avatar
Did you upgrade toa slimfan
Old Mar 22, 2008 | 05:18 AM
94GSRCivic's Avatar
Default Re: (tekturbo)
One more thing I would check would be the rad. cap. This gave me overheating problems for a while. It wouldnt hurt to check. Just my 2 cents.
jdizzy86
Jun 11, 2011 06:17 PM
h-o-n-d-a
22
Jun 19, 2009 07:22 PM
cambodia got civics too
Acura TL, RL & ZDX
Nov 9, 2007 03:51 PM
nabin
Aug 31, 2007 01:48 PM
