Correct Me If I'm Wrong D16Y5 Boost Question
Old Sep 11, 2014 | 05:37 PM
TRebel0EJ7's Avatar
Icon6 Correct Me If I'm Wrong D16Y5 Boost Question
So I got a 99 Civic Coupe HX 5 Speed D16Y5 VTEC-E
Going boost but keeping the stock engine and head and I'm not going to do nothing big just piecing a kit together and running it at 7-10lbs as this is my daily but just wanting to make it a little more fun so here's where I'm at
I know what I need for the turbo part of it meaning manifold, turbo, down pipe, waste gate, bov, intercooler, piping, fpr, fuel pump ect.
Ok Now this is where I need confirmation that I'm going about this right, what I'm planning is getting a y8 harness with a p28 ecu (unless I can possibly be able to use mine but I don't think I can) with "VTEC-E" engagement set at 2800k-3000k so I can get my full 16 valves going and the p28 will be used with a obd2a to obd1 jumper, and as for the 5 wire o2 on my y5 can I just use a y8 o2 with the y8 harness if I go that route, And would injectors be recommended as mine are only 190cc or so I believe it should to be safe
Old Sep 11, 2014 | 06:27 PM
turbohatch96y7's Avatar
Default Re: Correct Me If I'm Wrong D16Y5 Boost Question
you can use your hx harness if you know how to do some basic wiring.
Get a p28 with hondata or Neptune.
obd1 jumper harness.
You can get some 440cc injectors
For the d series im sure the limit is around 250 whp on pump gas.
Your best bet is to get a y8 head. and sell the y5 people will pay good money for it. Or sell the entire swap and get a straight ls or y8
I sold my y8 a couple years back for 800 bucks
Old Sep 11, 2014 | 06:41 PM
LTCxD2B's Avatar
I had a Jdm vtec-e and I swapped the valve train and cam for a z6 ... Maybe the y8 valve train and cam is all u need since swapping heads will give u super low compression
Old Sep 11, 2014 | 07:18 PM
TRebel0EJ7's Avatar
I was trying to avoid swapping any heads, intake manifolds, or any valve train to be honest just keeping it in a decent budget, I think I will just slap a decent turbo setup on with a 255lph pump with some 440cc injectors and run a p28 with a obd2a jumper harness on a tune with VTEC engagement set at 2700k for the VTEC-E and if something is to go wrong or blow I'll more than likely do the b18b LS swap I've been wanting to do.
Old Sep 11, 2014 | 07:24 PM
TRebel0EJ7's Avatar
Also what basic wiring will be needed, I'm guessing you mean the 5 wire o2 sensor, can I trick the ecu to thinking my secondary 4 wire o2 is my primary and get rid of the 5 wire o2 all together? I'm not worried about emissions or state inspections I got that covered
cheyna_22
Sep 6, 2012 12:22 AM
rossthab022
Mar 24, 2012 11:35 AM
B2KHonda
Jul 12, 2009 01:16 PM
DSC
Aug 27, 2004 07:53 PM
dogfood
Jun 17, 2004 08:18 PM
