Copper o-ring question PLEASE HELP
Old Feb 21, 2008 | 07:59 PM
jonathan_69's Avatar
Default Copper o-ring question PLEASE HELP
When you remove the head off of a block that has copper o rings in it do you have to replace the o rings before you put the head back on?
Also Cometic gasket will be fine on the o rings right?
Thanks
Jonathan
Old Feb 22, 2008 | 05:33 AM
Blown90hatcH's Avatar
Default Re: Copper o-ring question PLEASE HELP (jonathan_69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jonathan_69 &raquo;</TD></TR><TR><TD CLASS="quote">When you remove the head off of a block that has copper o rings in it do you have to replace the o rings before you put the head back on?
Thanks
Jonathan</TD></TR></TABLE>
Yes, you need to replace the o-ring. I don't know about cometic....I only run OEM.
Old Feb 22, 2008 | 08:24 AM
Antilag's Avatar
Default Re: Copper o-ring question PLEASE HELP (Blown90hatcH)
From what i heard, no cometic is not good for it.
Old Feb 22, 2008 | 09:16 AM
ctr83's Avatar
Default Re: Copper o-ring question PLEASE HELP (Antilag)
golden eagle takes oem head gasket and cuts them to size. thats if your bored over 81mm.
Old Feb 22, 2008 | 11:01 AM
HiProfile's Avatar
Default Re: Copper o-ring question PLEASE HELP (ctr83)
You'd have to call Cometic about it, but in general, MLS gaskets should work with copper wire. Its fiberous gaskets that use stainless wire, and all-copper gaskets usually shouldn't be o-ringed.
Old Feb 24, 2008 | 04:48 PM
TTT
Going to replace O rings....How do you get those damn things out. Heard of one guy very carefully drilling into the copper? Then you could get the pick tool in there and get em out. What's the best way to do this process
Also AEBS won't answer their phone. Have left messages. Still want more input on which gasket to use with the copper o rings or should i go with stainless o rings....
As of right now i have new cometic gasket.
Thanks for your input so far....
Old Feb 24, 2008 | 05:08 PM
DaveF's Avatar
Default Re: Copper o-ring question PLEASE HELP (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote"> MLS gaskets should work with copper wire</TD></TR></TABLE>
exactly. the Cometic MLS gaskets or OEM honda gaskets work..
to get the old o ring out, use a scratch awe and a hammer, tap the awe into the copper on a 45 degree angle it will buckle the copper, then you can pull it out with plyers. to install new copper wire, lightly tap the wire into the grove with the back of a screwdriver, or you can use a rubber mallet or dead blow hammer. get the ends tightly gapped, cut with normal wire cutters. be sure not to over lap or leave a huge gap where the ends meet
AllmotorEH2
Apr 10, 2007 04:55 PM
AllmotorEH2
Apr 9, 2007 08:21 PM
Chillinit
Jun 21, 2004 11:22 AM
forcedaccord95
Jan 29, 2003 07:29 AM
Chuji
Jul 5, 2002 10:10 PM
