coolant discolored in reservoir
my radiator has a small leak in it and i just noticed today that the coolant in the reservoir is a kinda reddish color. any suggestions on what my problem might be??
OG triple OG
Re: coolant discolored in reservoir (Jared)
ya it could be rust....hondas are known for that problem with the cooling system....orrrrrrrrrrr , did sombody accidently put extended life anti frees in because thats a reddish color
Re: (kid-honda)
I bet it had coolant additive or leak stop was add to the coolant... Do a coolant flush When I worked on customers cars at my dad's shop... Some reservoirs have the pasty reddish-brown junk on the bottom due to a additive added to the coolant!
Guest
Posts: n/a
i saw the same thing in my lexus. maybe it was what the factory used, but i dunno. just flush it out...then put some water in it...fill it all the way up. start the motor up, let it run a little, flush again. then pour in the real stuff and...tada, just like new and u wont have any red stuff in it anymore.
awesome, thanks for the replies!!! i'll flush it tomorrow and see whats going on. i know the radiator is leaking a little bit now - but i'm gonna get a new one soon. hopefully its just an addative and not the headgasket!!
Re: (B18bEK)
Most likely it's just a different brand of coolant. If you get your oil changed at those "quickie shops", they usually top off all your fluids. They just fill it with whatever they have...
Re: (Crazy Cooter)
i change my oil myself but i think when i did the swap a month ago i used red coolant and just don't remember . i'm gonna flush it today and see what the outcome is .
blackeg
09-14-2006 12:38 PM
