Confusing Dyno Results...
Old May 13, 2003 | 03:08 AM
T-Blaze's Avatar
Default Confusing Dyno Results...
Hey All.. I'm in need of some advise...
Setup: Del Sol B16A2 (stock), T3/T04e .48 ar .57 trim, Max Rev Manifold, Max Rev 2.5" DP, Tial EWG, 425cc inj, Uprated Fuel Pump, Ghetto MBC, Running the AFC Hack,
I initially got the car set up at the stock .45 spring in the WG.. I was quite happy with the results - (212whp, 175lb tq). I went back to the dyno last weekend to turn it up to 9lbs of boost using the MBC... and the results are 211whp, 192lbs of tq!!!
What could possibly be wrong?? I'm not sure of the A/F cos I never fot an AFR read out. Pls take a look at the comparison graphs below and see if u can notice anything..
Any advise will be appreciated.
[img]www.teamvt.com/hp.jpg[/img] [img]www.teamvt.com/tq.jpg[/img]
Modified by T-Blaze at 12:21 PM 5/13/2003
Old May 13, 2003 | 03:11 AM
T-Blaze's Avatar
Default Re: Confusing Dyno Results... (T-Blaze)
I'll try again wiv the images...
Old May 13, 2003 | 05:25 AM
echo999's Avatar
New User
I would think that either your exhaust is too restrictive, or you're running too rich
at higher psi.
Old May 13, 2003 | 06:01 AM
T-Blaze's Avatar
Thanx echo - Well funnily enough I had the same 2 theories... I think my Zorst defo needs changing cos it's just the stock 2.25".... That's gotta be holding me back.
I also noticed on the Air/Fuel gauge that it is running pretty rich higher up...
Any other suggestions any1.
Old May 13, 2003 | 06:19 AM
swlabhot's Avatar
Default Re: (T-Blaze)
Yeah, simple answer to that! U neez my 3" HKS Carbon-Titanium muffler. Its gotta be worth at least 100whp and 150 lb of Tq in it!!
Old May 13, 2003 | 06:22 AM
T-Blaze's Avatar
I reckon u should sell the Hiper to me and stick the 100whp Muff on ur Beast... U never know u could break the 300 mark... even without a tune!!
Old May 13, 2003 | 06:27 AM
swlabhot's Avatar
Errrmm, OH YEA!! didn't think of that! Good thinking Batman!
400whps getting closer by the day....
Old May 13, 2003 | 06:36 AM
NOSED_CRX_VTEC's Avatar
T-blaze just would like to know is you sol red?
Old May 13, 2003 | 06:37 AM
T-Blaze's Avatar
Yep - That's me dude...
Old May 13, 2003 | 06:51 AM
swlabhot's Avatar
Default Re: Confusing Dyno Results... (NOSED_CRX_VTEC)
Another fellow hacker. and we thought we are the only lone rangers here using the hack
U can't be spraying as well surely?!!?
Old May 13, 2003 | 07:00 AM
racinskittle's Avatar
Default Re: Confusing Dyno Results... (swlabhot)
Are you losing boost at all? It looks like you have a lot more potential out of that setup if you get it fixed.
Old May 13, 2003 | 07:04 AM
yer im using a 15shot of nos in low revs to get the turbo spinnig.
Not much of a shot but it give you that little bit more of a kick off of the line.
And its a back up when near the finish line.
Old May 13, 2003 | 07:07 AM
T-Blaze's Avatar
Default Re: Confusing Dyno Results... (racinskittle)
I don't feel like I'm losing boost, although the torque kick is a lot more now but for not as long..
It just feels like it really wants to go but then gives up b4 it can get there!!!
Old May 13, 2003 | 07:50 AM
T-Blaze's Avatar
C'mon... Wiv all the knowledge on this board I thought sum1 would have sum suggestions...?
Old May 13, 2003 | 07:55 AM
Johnyquest's Avatar
It seems pretty obvious to me. Your using a t3t4 hybrid with a .48 exhaust side AR. You need at least like a .68 for a b16 motor, or you lose boost at the top end b/c a .48 is too restrictive for your motor. It obviously spooled to the full 9lbs quickly, which explains your higher torque peak, but your turbo ran out of breath at the top just like it did last time, which explains your lack of top end power. Bottom line is a .48 AR is a D-series sized turbine, and is way too small for a B. That's your answer. You can see where it dies in the graphs.
Old May 13, 2003 | 08:03 AM
T-Blaze's Avatar
Surely that can't be right??? I was recommended this size tubby by Kyle... Surely it's capable of more than 9lbs.. and just over 210whp at that!!!!
Old May 13, 2003 | 08:05 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-Blaze &raquo;</TD></TR><TR><TD CLASS="quote">Hey All.. I'm in need of some advise...
well looks like your vtec stopped working or you running lean on the top end ... or your intercooler is shitty @ 9psi ... unless you look at your a/f graph thats the only way to tell my friend
greg
Old May 14, 2003 | 12:50 AM
T-Blaze's Avatar
I'll have to try and get hold of the A/F graphs.. But I also noticed an immediate drop in power as VTEC kicked in?? Could it also have something to do with cam timing??
Old May 14, 2003 | 03:38 AM
GOLDBERG's Avatar
post a/f graphs fo sure..the .48 could be limiting you some also....
Old May 14, 2003 | 04:39 AM
swlabhot's Avatar
The .48a/r is capable of way more than 210whp. Top end drop caould be due to the housing size tho.
U didn't mentioned the power drops as VTEC kicks in before?? I'd readjust the VTEC point higher up the rev range to see.
I think the tuner was on sum s##t when he was tuning it...Grease monkey
Old May 14, 2003 | 07:03 AM
b16ahybrid's Avatar
Default Re: (swlabhot)
244whp??? and 242hp....
am i missing something? You said 211hp but the graph shows 244hp..
Old May 14, 2003 | 07:10 AM
BoostedSi's Avatar
Default Re: (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">244whp??? and 242hp....
I was thinking the same thing. Am i just an idiot or am i also missing something
Old May 14, 2003 | 07:11 AM
b16ahybrid's Avatar
Default Re: (BoostedSi)
Maybe we're both idiots?????
Old May 14, 2003 | 07:19 AM
swlabhot's Avatar
The numbers on the graphs are all hp at the flywheel.
Old May 14, 2003 | 08:39 AM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">The numbers on the graphs are all hp at the flywheel.</TD></TR></TABLE>
Oh never seen that before
