confused about hack.
Old Jul 4, 2003 | 10:58 AM
2SLO's Avatar
Default confused about hack.
in my b20vtec turbo integra, can i just run my 450dsm's with resistor box and my Fields sfc-vtec and lean it out and be good to run 10 psi? even with no check engine? or will the map sensor read the 10 psi and throw a code? how exactly do i avoid that? sorry im kind of a n00b at the hack stuff.
Old Jul 4, 2003 | 11:14 AM
dirtySOHC's's Avatar
Default Re: confused about hack. (2SLO)
lots of ppl run 10 psi w/out a CEL although there have been that few that do through codes. just run 10 and find out
ppl rate the stock MAP up to 11.......maybe 12
Old Jul 4, 2003 | 04:43 PM
2SLO's Avatar
anyone else?
Old Jul 4, 2003 | 06:14 PM
1337 Si's Avatar
Default Re: (2SLO)
I know, stop being gay Randy!
Old Jul 4, 2003 | 10:56 PM
2SLO's Avatar
who this be y0? eric maybe?
Old Jul 4, 2003 | 10:58 PM
1337 Si's Avatar
Default Re: (2SLO)
Nooooooooooo
Old Jul 4, 2003 | 11:57 PM
senpai's Avatar
The Field's doesn't trim out enough fuel to work correctly ... in theory
InTeGrA B18b1's Avatar
Arent you suppose to use a Vafc because you can adjust from -+50
Old Jul 5, 2003 | 12:56 AM
kpt4321's Avatar
We are using a SAFC and DSM 450 cc/min injectors on a turbo 92 Integra at 10-11 psi with no problems.
tougeEGsies
May 2, 2004 03:05 PM
0 0 0
Jan 15, 2004 07:48 PM
dominate9
Nov 29, 2003 10:42 AM
turboegg
May 2, 2003 04:32 AM
KoRE
Sep 3, 2002 10:05 PM
