Compressor Map for a Hybrid (t3/04e)
Old Nov 5, 2003 | 12:19 PM
-Trinitron-'s Avatar
Default Compressor Map for a Hybrid (t3/04e)
According to all of the formulas I have found, it seems as though I have an idea of the flow rate my engine can produce. I have begun trying to figure out what trim will work best on my application. HOWEVER all the maps I can find are for standard turbos. For instance, a map for a t04e is barely useable for my flow rate. Is this not why we use a t3 turbine? Would this not change how the map reads because the compressor is being spun faster by less air volume?
Old Nov 5, 2003 | 12:29 PM
HXMan's Avatar
Default Re: Compressor Map for a Hybrid (-TRINiTRON-)
Hmmmm...turbine size shouldn't determine the possible flow rate of the compressor.
Old Nov 5, 2003 | 12:47 PM
I'm not asking about the flow rate possible. I am asking is the compressor map not different because of the different turbine. A normal honda motor does not move enough air to push a t04 turbine, therefore does not fit into the inner islands on the t04 compressor map. When mated with a t3 turbine the t04 compressor "sees" more flow coming from the turbine. So how do I tell which trim will be best for me? Am I just totally confused?
Old Nov 5, 2003 | 02:08 PM
grngsr01's Avatar
Good Question
Old Nov 5, 2003 | 04:14 PM
DigitalFusion's Avatar
bump for another confused person who is trying to plot compressor maps
Old Nov 5, 2003 | 04:24 PM
on second thought....
Correct me if i am wrong, but as I understand it, the turbine side has nothing to do with the compressor maps. They are COMPRESSOR maps. The turbine isnt a factor
Old Nov 6, 2003 | 06:38 AM
OK...Now I understand. I was confused...surprize! My real question was how do I know what A/R I will need. I know the bigger the number, the laggier the turbo will be. Is a t3 turbine with a .48 a/r or a .63 a/r better for a b-****-teen? (b16)
EGRhatch
Feb 14, 2012 12:53 PM
adictionbass
Dec 7, 2004 08:50 PM
boosted_zc
Dec 10, 2003 08:31 PM
swlabhot
Apr 4, 2003 09:02 AM
1.8EG-T
Aug 4, 2002 08:03 PM
