Compressor Map Holset he351cw Turbo
Old May 12, 2010 | 06:04 AM
aRandy's Avatar
Default Compressor Map Holset he351cw Turbo
Just like it says i just got an email from Holset containing the Compressor Map for a Holset he351cw Turbo.
I thought lets share it, i did notice a compressor map for this turbo a while back posted by the the.hamburglar but the map isn't exactly the same. https://honda-tech.com/forums/showth...ht=he351cw+map
Hope some people can use it
Old May 12, 2010 | 09:14 AM
fmfkid250's Avatar
Default Re: Compressor Map Holset he351cw Turbo
I had one on a stock ls It made 260 at 10psi. Turbos run very good on hondas (full boost by 5K)
Its little brother HE341 (03-04.5) I put on a mild SOHC build. It did 410 at 22psi and the clutch started slipping. wicked little turbos.
Old May 12, 2010 | 09:16 AM
Ryanthegreat1's Avatar
Thanks for sharing!
Am I reading that right? They don't even start to become efficient until you pass 1.5 bar?
Old May 12, 2010 | 09:24 AM
fmfkid250's Avatar
Semi Built D series. DSM 450s Yada Holeset HE341 Off my 2003 dodge.
Tired stock ls with the HE351 of a 2007 cummins.(my girl friends integra)
Old May 12, 2010 | 09:25 AM
fmfkid250's Avatar
on the D series we changed up some IC pipe after that. And the B series we took the 2.25 exhaust off.
Old May 12, 2010 | 09:26 AM
fmfkid250's Avatar
So anything below 14psi Is just Simply "not approved"
Old May 12, 2010 | 01:29 PM
welfarepc's Avatar
i ran one, got my D16A6 into the 10s but took a bucket load of boost.
made over 20psi by 5500rpm.
Old May 12, 2010 | 01:56 PM
Aesthetic Gains's Avatar
Dos Pupusas
Where is the map for the HE351VE?
Old May 12, 2010 | 02:04 PM
Captain Bondo's Avatar
Pretty sure the compressor wheel is essentially the same.
How do we convert the units on the x axis to corrected massflow in lb/min?
I'm haviung a hard time for some reason.
machine4321
Apr 14, 2010 04:02 AM
Stop the Beast
Mar 9, 2006 07:54 PM
