compression test went horribly
Old Sep 29, 2009 | 11:16 AM
  #26
Annihilator's Avatar
Default Re: compression test went horribly
Thank you so much guys! I got the valve lash close, I need to go re-adjust cylinder 3 a little bit, but it does have compression now!
148-142-130-148 are the current readings. What a relief. Thanks again guys.
- Steven
Old Sep 29, 2009 | 11:45 AM
  #27
NonovUrbizniz's Avatar
Loved
Originally Posted by komat
you go by the cam gear marking not crank pulley when doing valve lash
Hate to be a dick but no you're not.
Your turn the crank 180 to get the cam to turn 90... it even says so in your link.
Also you want which ever cylinder you're on to be at TDC... if you start at TDC of 1 and only rotate the crank 90 degrees you're at BDC of 1 and half way up the cylinder for 3.
Old Sep 29, 2009 | 11:48 AM
  #28
komat's Avatar
umm what you saying.
all i said was you go by the cam gear marking. you even quoted me
Old Sep 29, 2009 | 12:09 PM
  #29
Loved
You had quoted the previous poster who said turn the crank 180 degrees... you said you go by the cam gear...
Just wanted to clarify that you are turning the crank 180 degrees.
Old Sep 29, 2009 | 02:22 PM
  #30
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Yeah thank you for clarifying that for him... obviously he is lost.
You can go by whatever you want... if your camshaft timing is correct when the cylinder you want to set is at TDC then you set that cylinder, the next cylinder you go to in the firing order takes, guess what, 90* of a turn on the camshaft and 180* turn on the crankshaft.
To get VERY basic Hondas have 4-stroke motors AKA 4-cycle motors. There are (imagine this) 4 parts, AKA strokes, to the combustion process.
1.) Intake - Piston is moving down. Intake valves open, Exhaust valves closed.
2.) Compression - Piston is moving up. Intake valves closed, Exhaust valves closed.
3.) Power - Piston is moving down. Intake valves closed, Exhaust valves closed.
4.) Exhaust - Piston is moving up. Intake valves closed, Exhaust valves closed.
Well if you look at what just happened to complete one process. So when you translate that into how the motor works the crankshaft springs 360* TWO times to get the camshaft to turn ONE time. So if you looked at it that way it takes 720* of turning the crankshaft to get 360* out of the camshaft. Since there are FOUR parts to the process you divide each number by FOUR and you will get 180* for the crankshaft to every 90* of the camshaft...... OR ...... 90* for the camshaft for every 180* of the crankshaft.
I turn all of my motors by the crankshaft like it is meant to be done... therefore I was telling the OP to turn his crankshaft 180* to get his camshaft to turn 90*... if your motor is not even close to having the valves closed when you do this then you have MAJOR problems. Since these are interference motors you most likely would have bent valves now if you turned the motor over hard enough. The camshaft marks are just for reference but you should always get a visual on the base circle of the cam to be sure.
Old Sep 29, 2009 | 02:45 PM
  #31
postman's Avatar
no offense, but how did you put an engine together and not know how to adjust valve clearance. seems odd to me.
and you do go by the camshaft markings. the camshaft isnt technically at 100% tdc when doing clearance, and its not supposed to be. which is why you use the cam markings.
Old Sep 29, 2009 | 03:53 PM
  #32
Bullettdsm's Avatar
- Steven
Good for you. Don't sweat the ball bustin'. You're working on your own car and learning. As you said previously, you also consulted an experienced mechanic to help you.
Gotta crack a few eggs to make an omlet. Sometimes you gotta ask a few questions to learn how its done.
MB
Old Sep 29, 2009 | 04:54 PM
  #33
srmofo's Avatar
glad you got her sorted, theres only 1 way to learn and if you have never done it before, how will you ever know if you can do it?
Just wait till the first time you crack a transmission case open to attempt your first rebuild. that'll have you scratching your head for a few days until you understand how every thing works together.
Old Sep 29, 2009 | 08:15 PM
  #34
wunfstgsr's Avatar
Loved
Community Favorite
is it cyl. 3 that looks a bit low did you try adding a drop of oil to see if it rose? but never the less comp. looks good to me how does it perform?
Old Sep 29, 2009 | 09:18 PM
  #35
oh the engine is night and day now. I'm very thankful that I had everything balanced when I put it together, it vibrates less with my innovative mounts now than it did with the D series.
As for performance, I can't really say yet. I have to get a downpipe built so I can install my wideband, and I also need a new flywheel as I made another mistake there...but that's a whole new can of worms. I'm hoping I can start driving it again in a week or two. Sooner is better as it's starting to get cold, so riding my 250 is getting old.
Thanks again everyone, I can sleep well tonight finally haha
- Steven
Old Sep 30, 2009 | 07:58 AM
  #36
keving85's Avatar
if you adjust your valves and no avail then it sounds like you have the engine 180 degrees out.
Old Sep 30, 2009 | 09:11 AM
  #37
90civichbsi's Avatar
lol to that... I've never rebuilt an engine but I rebuilt my trans 3 years ago and ended up taking it out twice and pulling apart due to stupid mistakes. Needless to say I could probably do it in my sleep now. Its all a learning experience.
Team_Coast978
Engine Management and Tuning
Jun 10, 2013 10:58 AM
rxbahamut
Oct 17, 2011 06:33 PM
zerovandez
Oct 3, 2011 05:38 PM
Jibin
May 21, 2009 05:58 PM
turbo_ef4
Feb 17, 2006 11:55 AM
