Compression Test Numbers???
Old Jan 25, 2004 | 05:06 PM
Clutch101's Avatar
Default Compression Test Numbers???
What is normal cylinder pressure readings when doing a compression test on a B16 with JE 9:1cr pistons?
I know what the stock cylinder pressure readings are for the factory compression ratio, just looking to figure out what they should be for lower compression.
Is there a rule of thumb to follow when lowering compression for forced induction?
Thanks for any info.
Old Jan 25, 2004 | 05:11 PM
tegasaurus's Avatar
Default Re: Compression Test Numbers??? (JDMwannaB)
my 9.2:1 pistons on a b18a w/ b18b head produced about 200psi. but then again i was told they were 9.2:1 and they never came in official packaging etc... so i dunno. You should see somewhere between 180 and 210, numbers don't matter THAT much, so long as they are all within a couple of psi of each other (for a rebuilt motor).
-Ryan
88 civic
Apr 5, 2009 03:21 PM
NuclearB18B
Jul 2, 2005 03:01 PM
builtprelude
Jan 22, 2004 10:49 PM
DXDOHCVTEC
Sep 3, 2003 04:39 PM
