compression test numbers
Old Jun 26, 2002 | 03:05 PM
KLN's Avatar
KLN
Default compression test numbers
1994 LS engine with 115,000 miles
#1 = 180
#2 = 180
#3 = 180
#4 = 190
cylinders 1-3 were a lil' over 180, but i rounded down.
are those numbers good enough to turbocharge my car?
i'm not too familar with the numbers for my engine, so any help would be appreciated..
thanx
[Modified by KLN, 12:06 AM 6/27/2002]
Old Jun 26, 2002 | 03:13 PM
jinxproof99's Avatar
New User
Default Re: compression test numbers (KLN)
thats decent for your compression. turbo it.
Old Jun 26, 2002 | 03:18 PM
jamal-188's Avatar
Default Re: compression test numbers (jinxproof99)
yeah yeah, turbo!!!! If you blow it up just rebuild and boost more!!! You should be okay though, numbers aren't too bad.
Old Jun 26, 2002 | 03:49 PM
JASON77's Avatar
Default Re: compression test numbers (jamal-188)
Just wondering what good numbers are since my friend is coming over after work to do a compresion/leak down check on my engine (94 ls sedan with 110,000 miles on it) ?.......if they are good then i will go ahead with the supercharger....next week.
Old Jun 26, 2002 | 11:13 PM
KLN's Avatar
KLN
Default Re: compression test numbers (FREAKA)
well i have the exact same car and engine as yours, if people say my numbers are decent, then i'll assume that if your numbers are close, then the motor is still good
Old Jun 27, 2002 | 03:02 AM
modvp's Avatar
Those are good #'s. I have a 1995 B18B teg with 107,000 miles. I've had a turbo on the car for 47000 miles (dragIII) and my compression was 190 (on all 4 cyl.) before turbo and it's still at 190. I use castrol syntec 5w50 religiously, and change my oil every 3000-5000 miles.
Go for it!
Old Jun 27, 2002 | 03:56 AM
Smooth-GSR's Avatar
Default Re: compression test numbers (modvp)
What should your comp numbers be on a 94+ ls if your going turbo? Seems like people are saying the difference between the numbers is more important, but if everything reads 140, I'd be worried.
Anything else that should be checked before an ls turbo?
Old Jun 27, 2002 | 04:22 AM
RGAZ's Avatar
New User
Default Re: compression test numbers (Smooth-GSR)
Consistently low is not a real bad thing, it just means that the rings aren't sealing as well as they have in the past. The oddball number is what should scare you.
Other things to check:
Oil pressure cruising at 3000 rpm and warm engine. If you don't have at least 40psi of pressure, then your bearings are on the way out. Just another check.
Clutch: If you have an old stock clutch, it might bite the bullet soon after the turbo is installed. Check it now.
Randy
Old Jun 27, 2002 | 08:35 AM
JASON77's Avatar
well I got #1-4 in that order.....200,190,190,190.....so its a go for the supercharger next week
man I cant wait!......thinks to him self that very soon he will be able to change his signature
Old Jun 27, 2002 | 10:35 AM
modvp's Avatar
don't do the supercharger...
go for the turbo!
Old Jun 27, 2002 | 11:24 AM
JASON77's Avatar
I have thought about the two for a long time and have decided that the supercharger is what I will go with. this will be my daily driver (only have one car right now) I am not going for huge hp numbers right now, I am just doing this more because its fun than anything else......more power low end.....
maybe in a few years I will go with a turbo, although most likely with a different car than a integra......maybe 350z or something I don't know
Old Jun 27, 2002 | 11:32 AM
modvp's Avatar
I've got a 1995 integra B18B and 4 years ago, based on the same rational, i wanted to go with the jackson supercharger.
Then i was comparing the performance from guys on hostboard with those who have tried turbo on this borad and In the end, i went turbo and i've been running turbo for over 2.5 years without a single problem. It's my only car, and i've put over 47000 miles on the turbo without ANY problems. Get the turbo, it will be just as cheap and very flexable and easy to upgrade.
Old Jun 27, 2002 | 11:44 AM
JASON77's Avatar
Thanks, but like I said I do plan on getting a second car down the road a bit (no pun intended with road/car ha ha em oo sorry bad joke) anyway right now its all set up my friend is going to help me this coming week, I also have a auto trans in my car right now. I do plan on swapping it out for a manual in the future but for right now, this being my first forced induction experience I am going with the super charger.... thanks for the advise I do appreciate it but its the super charger for me now....down the road a bit who knows
Old Jun 27, 2002 | 12:11 PM
ion_four's Avatar
Hey modvp, what kind of engine management do you have, what kind of boost are you running? I've got a hair over 100k on my d16z6 and I'm going to be putting a custom turbo on it in the next few weeks...just wondering what you're doing to make it run so well.
Old Jun 27, 2002 | 12:40 PM
modvp's Avatar
Default Re: compression test numbers (ion_four)
I'm using stock engine management with RC 310cc and vortech 8:1 FMU. I run 7 psi daily and 9psi for fun.
Old Jun 27, 2002 | 12:44 PM
fuguman's Avatar
New User
what are you running for setup?
BTW
I just got my comp test done
200 200 195 210
any thoughts on that?
is the last one too hight?
95 b18b with 112K on it
i NEED to go turbo!!!!
[Modified by fuguman, 9:47 PM 6/27/2002]
Old Jun 28, 2002 | 01:05 AM
modvp's Avatar
Default Re: compression test numbers (fuguman)
Fuguman,
You should go turbo. #'s are really good. Stock comp #'s are approx 200psi for B18B. You may have some carbon build up or your guage maybe a little optimistic. However, the #'s are consistant.
I'm running a DragIII kit (T3/T4E; 50 trim comp., 0.63 A/R stg.3 turbine), RC 310cc, 2.25 SS Magnoflow exhaust, with greddy profec b boost controller.
Old Jun 29, 2002 | 07:21 AM
fuguman's Avatar
New User
Fuguman,
stock internals?
GokuSs4
Apr 26, 2004 12:47 PM
Andrew 825SM
Sep 15, 2002 10:30 AM
Phat Corolla
Aug 13, 2002 03:50 PM
OneThirtyEight
Sep 5, 2001 04:48 AM
Lei Siew Long
Jul 10, 2001 11:54 PM
