Compression Test with the motor out
Old Mar 25, 2002 | 11:49 AM
LsTurbo91's Avatar
Default Compression Test with the motor out
Is there anyway to do a compression test with the motor off the car and no tranny?
Old Mar 25, 2002 | 12:44 PM
ATurboCivic2NV's Avatar
Default Re: Compression Test with the motor out (LsTurbo91)
is the starter hooked up? just turn it over a few times. you not suposta have the fuel or spark hooked up anyway.
Old Mar 25, 2002 | 01:06 PM
qwkteg125's Avatar
Default Re: Compression Test with the motor out (ATurboCivic2NV)
and no tranny
doesn't look like using the starter is an option...
Old Mar 25, 2002 | 01:10 PM
Default Re: Compression Test with the motor out (qwkteg125)
it bolts on to the tranny? can you just get an impact and turn it over at the crank?
Old Mar 25, 2002 | 01:14 PM
rainforest's Avatar
get the tranny put the starter in then arc a wrench onthe starter. (between the to wire) and it will want to start. thats how you can do it.
armash
13
Sep 23, 2006 04:51 PM
spike
Dec 29, 2004 02:37 PM
Propulsion
Feb 14, 2003 11:11 AM
DR. ON POINT
Oct 30, 2001 01:43 AM
