Compression test done
Old May 21, 2006 | 12:34 PM
EK k kay's Avatar
Default Compression test done
I had some headstuds put in yesterday for my upcoming turbo setup so I figure I should do a comp test. On a warm motor at wot here are the results:
193 181 188 190
Does it matter if I didn't take out all of the spark plugs? I took one out and tested that cylinder then put it back in and so on.
This is on a stock y7 block with a stock y8 head.
Old May 21, 2006 | 12:50 PM
coneheadsracing's Avatar
Default Re: Compression test done (EK k kay)
not bad, but i think they are suppose to be within 15% of eachother. I that same motor last fall, after boosting 15 psi, i was like 220 in each cylinder, so i don't know.
Old May 21, 2006 | 01:17 PM
s2kdre's Avatar
Default Re: Compression test done (coneheadsracing)
U have to take out all the plugs and unplug the distributor and test it on a cold motor.
Old May 21, 2006 | 01:30 PM
EK k kay's Avatar
Default Re: Compression test done (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda &raquo;</TD></TR><TR><TD CLASS="quote">U have to take out all the plugs and unplug the distributor and test it on a cold motor.</TD></TR></TABLE>
Cold? All the threads I have read have said to test it while it's warm.
Old May 21, 2006 | 02:10 PM
warm engine, and you don't have to take out all the plugs at once, your only testing the one cylinder.
Old May 21, 2006 | 02:34 PM
KeyserSoze's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">not bad, but i think they are suppose to be within 15% of eachother.</TD></TR></TABLE>
Maybe I'm a little confused here not knowing if that 15% is from the lower, the higher or the average of the numbers, but.....
(.15)*181 = 27.15, 181 +/-27.15
or
(.15)*193 = 28.95, 193 +/-28.95
or
(.15)*188 (ave) = 28.2, 188 +/-28.2
So it seems whether you take the higher, the lower number or even average them he is well within 15%. Right? Just curious.
Old May 21, 2006 | 03:32 PM
y7turbo's Avatar
i have a y7 that i just rebuilt here are my numbers as of last night
195
195
190
195
as long as they are close and above spec they are fine man..
Old May 21, 2006 | 05:57 PM
drintegra's Avatar
Default Re: Compression test done (KeyserSoze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KeyserSoze &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I'm a little confused here not knowing if that 15% is from the lower, the higher or the average of the numbers, but.....
or
or
So it seems whether you take the higher, the lower number or even average them he is well within 15%. Right? Just curious. </TD></TR></TABLE>
15% from each other. Basically the numbers should not be more then like 20-25 psi from each other.
Old May 21, 2006 | 10:46 PM
LilCivic04's Avatar
whats the difference between WOT and not? i mean how much of a difference will we see?
djcurtis59
Honda Civic (2001 - 2005)
Jul 4, 2011 12:51 PM
10sec4door
Apr 20, 2010 11:01 AM
Fat Chick Magnet
Sep 28, 2006 06:24 PM
b18bme
Apr 6, 2006 11:01 AM
AspectIndustries
Aug 15, 2004 02:31 PM
