compression test after 5months of boosting.....
Old Oct 30, 2004 | 01:04 PM
AznInvasion's Avatar
Default compression test after 5months of boosting.....
before i slapped on my custom turbo kit my compression was around the area of
240 235 240 235
now 5months later after running 10psi all summer on a bone stock GSR
with hondata. my compression now reads 240 210 210 210.
anything above 200 is good rite ? i plan on taking my turbo kit off and going back to stock due to financial reason and was wondering my motor should last me awhile rite after it was boosted?
Old Oct 30, 2004 | 04:18 PM
JDMs1eeper's Avatar
Default Re: compression test after 5months of boosting..... (AznInvasion)
get yoru valves re adjusted, then check compression. you will be happy with the results.
Your motor is fine...
Old Oct 30, 2004 | 06:23 PM
danl's Avatar
Banned
Default Re: compression test after 5months of boosting..... (JDM S1eeper)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM S1eeper &raquo;</TD></TR><TR><TD CLASS="quote">get yoru valves re adjusted, then check compression. you will be happy with the results.
Your motor is fine...</TD></TR></TABLE>
How would valves be out of adjustment on 3 cylinders and not all 4? Or does the one cylinder spin slower than the others causing it to keep its lash in spec longer?
Old Oct 31, 2004 | 07:07 PM
00s2KkId's Avatar
just because 1 or 2 or maybe even 3 cylinders go out of adjustment doesnt means the others will go out of adjustment with them... they all can change differently
ChronicGreenDC2
Jun 24, 2005 09:30 AM
SwiftTypeR
May 10, 2005 05:22 PM
sdinteg
Feb 1, 2005 07:52 PM
LostGsr
Jun 15, 2001 12:29 PM
