Compression ratio
Old Feb 2, 2008 | 01:24 PM
hybridmath's Avatar
Default Compression ratio
im not new to honda-tech or hondas in general but im new to this recently built my first engine from the ground up but i am running into a problem where im losing anti freeze so im obviously thinking head gasket so i checked out the normal plugs oil under the valve cover no sludge i got 180 185 180 180 across the board
is this normal??? i expected it to be a little higher than that considering the engines only got 4000 miles on it
engine spec's
b18c
golden eagle sleeves bored 84.5mm
cp pistons 8.5.1
eage h beams
fully balanced
gsr head
full port and polish
3angle valve job
skunk 2 titaniaum retainers and valve springs
Old Feb 2, 2008 | 02:59 PM
crxsir23's Avatar
Default Re: Compression ratio (hybridmath)
if it was a head gasket it should smoke white, how about a leak? it could be evaporating and you don't even know its there
Old Feb 2, 2008 | 05:48 PM
hybridmath's Avatar
Default Re: Compression ratio (crxsir23)
i see a little white puff here and there that dosent dissipate im in ct so really cold here hard to tell i go through like a gallon every week week and a half so its a considerable amount for an unseen leak my main ??? is about the compression per cylinder it is a low compression engine but 180 per cylinder seems low to me
Old Feb 2, 2008 | 05:51 PM
hybridmath's Avatar
the engine only has 4000 miles or so on it so im very worried at this point got alot of money into it
Old Feb 2, 2008 | 06:25 PM
carzntune's Avatar
Compression #'s are consistent and don't seem low for the pistons used.
Old Feb 3, 2008 | 12:56 PM
hybridmath's Avatar
thnx for the info guys much appreciated
Old Feb 3, 2008 | 07:48 PM
Garage 808 Hatch's Avatar
If you want to rule out a headgasket leak, put a leak down tester on it, and pull the radiator cap off, and see if any air bubbles appear in the radiator, this will tell you if you have a leak
JENNY_EG6
15
Jul 9, 2010 02:14 PM
soulo
May 9, 2009 09:29 AM
nemesis25
Apr 8, 2009 04:24 PM
wicked_b16eg
Dec 29, 2007 06:39 PM
