compression after rebuild?
Old Jul 24, 2002 | 06:44 PM
GruvyTune's Avatar
New User
Default compression after rebuild?
ok, only have like 10 miles on my new rebuild:
b18C1 with 9:1 JE pistons, stock headgasket and arp studs with eagle rods and new valve seals. before rebuild before engine blew i had 190 across the board with 76K on the engine.
after rebuild with lower compression pistons i have 185-190 across the board.
Is that what i should expect with lower compression pistons? I have little signs of any burning oil now so i figure the rings are seated?
did test with cool engine, all plugs out and throttle wide open, i suspect it would be higher if the engine were warm?
thanks!
torin
[Modified by GruvyTune, 10:52 PM 7/24/2002]
Old Jul 24, 2002 | 08:58 PM
boostaholic's Avatar
Default Re: compression after rebuild? (GruvyTune)
Your compression numbers look good.
Old Jul 24, 2002 | 09:31 PM
Projekt20's Avatar
Numbers look about be right....I usually see 210-220 across on stock B18Cs....so maybe you were due a rebuild. Test when it's warm though, just to make sure. I hope I get numbers as good when I get mine back.
95c1v1cs1
Apr 21, 2003 11:29 AM
311
Dec 14, 2002 12:18 PM
shamoo
Sep 25, 2002 02:53 PM
DLB1994
Sep 2, 2002 03:34 AM
GruvyTune
Jul 24, 2002 07:49 PM
