compression is 120's across the board and i have no power
i misshifted at the track last week and thought i just blew my headgasket some, it was eating up coolant gradually on the way home and smoking, but it wasnt too bad. so the next day i put in a new headgasket. i went to take it for a drive and it had absolutely no power at all, it was as if the motor was under an extreme amount of load and taking off in first felt like taking off in fifth. it wasnt like this on the way home from the track, only after i changed the headgasket. i then did a compression test and it was 120ish across the board. i also noticed that after the engine got up to operating temp i can hear a slight knock/tick, and it speeds up with the rpms. is there a chance i spun a bearing or is it most likely bent valves or something?
Re: compression is 120's across the board and i have no power (civicskater)
motor is prolly done, spun a bearing or bent some valves, u should have done a compression test before the head gasket
Re: compression is 120's across the board and i have no power (Chris Tune)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris Tune »</TD></TR><TR><TD CLASS="quote">putting back the Tbelt owned you maybe?</TD></TR></TABLE>
Thats what I was thinking, Maybe a tooth off?
i ♥ snails
yeah thats a good possibility, timing belt skipping teeth because if all 4 cylinders are reading same compression it had to effect the entire motor and not just individual cylinders.
that's my vote. probably more then a few teeth off.
the tick could be an exhaust leak. or it could be a bearing...hard to say with so little info.
Re: compression is 120's across the board and i have no power (Bailhatch)
cam timing off is my vote
if it changed when you did the HG think about WHAT CHANGED during that process you didnt hurt the valves or bottom end changing the headgasket.
was it weak before the HG? or after
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicskater »</TD></TR><TR><TD CLASS="quote">i misshifted at the track last week and thought i just blew my headgasket some, it was eating up coolant gradually on the way home and smoking, but it wasnt too bad. so the next day i put in a new headgasket. i went to take it for a drive and it had absolutely no power at all, it was as if the motor was under an extreme amount of load and taking off in first felt like taking off in fifth. it wasnt like this on the way home from the track, only after i changed the headgasket. i then did a compression test and it was 120ish across the board. i also noticed that after the engine got up to operating temp i can hear a slight knock/tick, and it speeds up with the rpms. is there a chance i spun a bearing or is it most likely bent valves or something?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls »</TD></TR><TR><TD CLASS="quote">cam timing off is my vote
was it weak before the HG? or after</TD></TR></TABLE>
Reading > You
Reading > You
Re: compression is 120's across the board and i have no power (StockDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StockDC2 »</TD></TR><TR><TD CLASS="quote">
Reading > You </TD></TR></TABLE>
no obviously ownz you. that was more of a sarcastic question as in think about this_____
i dont think you have the required equipment to be "smart" ***.
Re: compression is 120's across the board and i have no power (agrn93ls)
I miss a shift last year, when I pull the head I can't see anything.
Once the pistons were clean, all 8 ex valves hit the pistons and 6 of the curb.
2 were very curb. This pistons read 30 psi less than the others.
Turn your head upside down and drop some paint thinner in it, if it's leak in the port, than some valves don't close correctly.
H22AFerio
10-09-2011 11:23 AM
PM-Performance
08-08-2003 11:05 AM
