Is this a complete turbo kit?
Old Dec 25, 2007 | 11:27 AM
DC2_8.2K's Avatar
Default Is this a complete turbo kit?
I'm planning on getting a d-series turbo kit for my car. I'm wondering, is this a complete kit or am I missing anything? Let me know! Thank you.
• 1x D-Series piping kit: 4 pieces total for turbo and intercooler setup. Light weight aluminum design. Adjustment are needed depends on engine layout and different setups.
• 1x JDM sport Intercooler: tube and fin design, 28x7.5x2.5 inch cord size.2.5inch in/outlet diameter, handles up to 30psi/500hp.
• 1x JDM sport T3/T4 Hybrid turbo w/ random filter: brand new built with 3inch diameter inlet, 2inch outlet, .50 A/R compressor, .63 A/R turbine .57 trim, and oil cooling system. 50+whp gain.
• X1 Stainless steel turbo manifold: Higher Resistance to Heat, Made to fit D15/D16 Series Engines, Bolt on Manifold. Fits with t3/t4 hybrid turbo and 35mm/38mm wastegates. Professional Installation Highly Recommended.
• 1x Turbo Downpipe: JDM advanced technology constructed. 2.75 inch diameter inlet /outlet. Direct connection with 5 bolt design to t3/t4 turbo. Also comes with downpipe flange and gaskets.
• 1x JDM Type S style Blow off valve w/ bov adapter: Quick response with high capacity Up To 1200HP or 25 PSI of Boost Pressure. Professional Installation Suggested. Aggressive blow off sound comes with bolt flange and hardware. Adapter piping can be bolt on or weld on, easy installation.
• 1x 38mm tail style wastegate w/ hardware: wastegate body and valve are investment cast from 253MA Stainless Steel (ASTM S30815).It intended to withstand high temperature and flow capability. With Turbo Boost Controller you will able to Adjust Spring rate from 1-30 Psi w/o Change Springs.
• 1x Turbo Boost Controller: in order avoid replacing wastegate springs, which only give a fixed increase, which is not adjustable, a boost controller will be the most cost effective solution. Allows adjustable boost psi settings, light weight design to be mount under the hood. Hardware is included.
• 1x Fuel pressure regulator.
• 1x Cam gear.
• 4x Dsm fuel injectors.
• 1x Vtec controller.
• 1x JDM Oil Feed Line: designed to limits oil flow, prevent blown oil seal. 36 inch long with 3/8 diameter stainless steel line, hardware and gasket is included w/ 1/8 inch fittings for the engine.
• X6 silicon sealing couplers & x12 T-bolt clamps: 2.75 inch diameter couplers (color maybe vary) with flexible steel T-bolt clamps for better and stronger holdings to prevent leaking.
Modified by just_hatched at 2:44 PM 12/25/2007
Old Dec 25, 2007 | 11:31 AM
jewjew bean's Avatar
Default Re: Is this a complete turbo kit? (just_hatched)
just provide us with the ebay link
Old Dec 25, 2007 | 11:39 AM
DC2_8.2K's Avatar
Default Re: Is this a complete turbo kit? (jewjew bean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jewjew bean &raquo;</TD></TR><TR><TD CLASS="quote">just provide us with the ebay link </TD></TR></TABLE>
Sorry, I dont shop in Ebay. It's actually a site that sells performance parts.
Old Dec 25, 2007 | 12:02 PM
coneheadsracing's Avatar
I'm bored
http://www.advancedjdmparts.co...16865
Old Dec 25, 2007 | 12:08 PM
H.Veras's Avatar
You are missing a new MAP sensor, and something to control the bigger injectors and ignition timing.
Old Dec 25, 2007 | 12:11 PM
DC2_8.2K's Avatar
Default Re: (H.Veras)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H.Veras &raquo;</TD></TR><TR><TD CLASS="quote">You are missing a new MAP sensor, and something to control the bigger injectors and ignition timing.</TD></TR></TABLE>
Like what? Thanks for the info.
Old Jan 1, 2008 | 09:38 AM
VeeL_B20's Avatar
Default Re: (just_hatched)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just_hatched &raquo;</TD></TR><TR><TD CLASS="quote">
Like what? Thanks for the info.</TD></TR></TABLE>
To run those injectors you need the resistor box. You can find it in the turbo dsm cars (junkyard) or (ebay). Look into a chipped ecu as well, you'll love it!!! You'll need a better fuel Pump and a few other things but you'll be fine for now. GOOD LUCK!!!
Old Jan 1, 2008 | 10:00 AM
krazyhmongboi's Avatar
maybe im just not seeing it but you'll need a oil return line/fittings
o and btw are you piecing the kit together or is it a kit already? how much?
edit: i checked out the link...it looks like a kit you'd find on ebay with a different name
Old Jan 1, 2008 | 01:50 PM
EJ1 wilcox's Avatar
Default Re: (krazyhmongboi)
That's not a complete kit at all. It doesn't even have complete piping.
Don't waste your time/money.
Old Jan 1, 2008 | 02:52 PM
Schister66's Avatar
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just_hatched &raquo;</TD></TR><TR><TD CLASS="quote">Sorry, I dont shop in Ebay. It's actually a site that sells performance parts.</TD></TR></TABLE>
• 1x JDM Oil Feed Line</TD></TR></TABLE>
Don't fool yourself. Even if this is a "Performance Shop" they're still peddling Ebay garbage. Did you even read that bullshit you posted?? I wouldnt touch that turbo setup; regardless of how "good" the price is...
Old Jan 1, 2008 | 03:35 PM
TDogg Teg's Avatar
Default Re: Is this a complete turbo kit? (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">
http://www.advancedjdmparts.co...16865</TD></TR></TABLE>
Peep the ssac style mani. (hehe!)
Old Jan 1, 2008 | 04:11 PM
Ekb18c5_BR's Avatar
Default Re: Is this a complete turbo kit? (TDogg Teg)
you can also look into this people on ebay, the turbo kit looks good....
http://cgi.ebay.com/ebaymotors...ZWDVW
Old Jan 1, 2008 | 04:33 PM
Schister66's Avatar
Man U FTW
^^That Vecco kit is junk as well....
Old Jan 1, 2008 | 04:38 PM
Ekb18c5_BR's Avatar
Default Re: (Schister66)
really ????????
why dude???
Old Jan 1, 2008 | 04:50 PM
blue2000em1's Avatar
Default Re: (Ekb18c5_BR)
I honestly thought that the vecco turbo kit would of been a good kit guess not.
Old Jan 1, 2008 | 04:51 PM
93CX's Avatar
its garbage.. but hey we all ran one at some point.. either search or learn for yourself the hard way
mustanggtandgsxr's Avatar
the only thing i see wrong with this kit is that you have to weld and fabricate the down pike kit and the dumptube kit and the blowoff valve is cheap. i almost bought this kit but a brand new peakboost kit posted on ebay(for cheap) the day i was going to buy this kit so i didnt.
Modified by mustanggtandgsxr at 6:05 PM 1/1/2008
Old Jan 1, 2008 | 04:59 PM
Ekb18c5_BR's Avatar
i don't think it's that bad either....
Old Jan 1, 2008 | 05:22 PM
TIGboy's Avatar
ok, are some of us here blind? thats a top notch SSAC full blown ebay kit....ya know I would really like to see fullrace and other name brand companies to produce a kit with that much **** in it and see how much it would cost with legit parts...
I love this part
"Aggressive blow off sound comes with bolt flange and hardware. Adapter piping can be bolt on or weld on, easy installation." cant beat that sound
god....
Old Jan 1, 2008 | 05:28 PM
Default Re: (TIGboy)
I do know alot of people say that they use turbonetics Housings.But have chinesse internals .
benclimber17
Mar 2, 2008 02:21 PM
fullybuiltracing.com
Dec 8, 2007 05:16 PM
IKNOWHONDAS
Texas -OK -LA (Sales)
Aug 18, 2006 06:22 PM
VTcivicEG
Aug 19, 2005 07:58 AM
