Comp Clutch Twin disc ??
Old Jan 3, 2006 | 11:05 PM
D@nnY's Avatar
Default Comp Clutch Twin disc ??
How many people are running the competition clutch twin disc?
Theres alot of talk about having to make a pedal stop and shave down the rear main seal to make it work....
Has anyoen delt with these things? how did the pedal stop work out?
Old Jan 4, 2006 | 04:44 AM
93H22ACX's Avatar
Default Re: Comp Clutch Twin disc ?? (D@nnY)
we're using the competition twin disk on both our cars. we didnt have to do anything with the clutch pedal. although we did have to shave some of the bolts that went through the flywheel. some others that use them didnt have to do anything for installation.
Old Jan 4, 2006 | 05:22 AM
anothaRRR's Avatar
Default Re: Comp Clutch Twin disc ?? (93H22ACX)
I think on mine Dseries flywheel bolts were used, forgot... But other than that, that was it....Works like a charm...
Old Jan 4, 2006 | 04:42 PM
D@nnY's Avatar
Default Re: Comp Clutch Twin disc ?? (anothaRRR)
is everyone happy with the clutch?
Old Jan 4, 2006 | 09:46 PM
D@nnY's Avatar
up
Old Jan 4, 2006 | 10:12 PM
Boostfed's Avatar
New User
I run one, mine has a heavy duty pressure plate due to the horsepower I told Competition Clutch I was planning on making. Had to adjust pedal BUT I am gonna make a pedal stop since I hear it works better actually, also had to shave the oil pan and main seal to clear the bolts on the flywheel. Jason Hunt runs one on his Coupe also and maybe on the CRX, all good!
EDIT:Oh yeah you have to use SOHC Manual flywheel bolts also, keep in mind B series use 8 Flywheel bolts and SOHC only use 6. My buddy sent me some and I was like you shorted me man! lol
Old Jan 4, 2006 | 10:14 PM
T4eg's Avatar
im using comp twin disc now. awesome clutch i used sohc bolts... no problems, didnt have to modify anything just normal clutch install. Was kinda iffy it came with NO tq specs or anything along those lines. But i contacted Boostfed and got them (thanks again) . So comp clutch gets from me.
Old Jan 4, 2006 | 10:20 PM
D@nnY's Avatar
i would think by using a spacer your moving the flywheel and pressure plate out and it would cause the throw out bearing to have less travle and possibly cause the fingers on the pressure plate to hit the disc
Old Jan 4, 2006 | 11:30 PM
HYBRID_H@TCH's Avatar
Default Re: (D@nnY)
when I got mine it came with new bolts and everything..mine did not need to be reworked at all and kicks ***!!
Old Jan 4, 2006 | 11:58 PM
D@nnY's Avatar
Default Re: (99Hybrid_Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99Hybrid_Hatch &raquo;</TD></TR><TR><TD CLASS="quote">when I got mine it came with new bolts and everything..mine did not need to be reworked at all and kicks ***!!</TD></TR></TABLE>
thanks for the info im glad you car is doing so good!!
I got the exedy already from boostfed so ill do a review when it gets here
Old Oct 28, 2013 | 12:14 PM
boostlsveg's Avatar
So I know this is an old thread and all but im just wondering if u still r supposed to use sohc flywheel bolts or trim down the ones that bolt on the pressure plate cuz I just put mine on the other day n I didn't notice anything that would b a problem but maybe I didn't look hard enough since I wasn't aware of this. I just used the flywheel bolts that came with the kit. And I do understand that I will need to make a pedal stop. But also i didn't trim my throw out bearing at all it seemed like it would work. Thanks
Old Oct 28, 2013 | 12:32 PM
rudebwoy's Avatar
mine is great, did not have to shave any bolts or seal, and I have one of the earlier ones, I've noticed the pressure plate bolts are little too long but they don't touch anything, I am thinking of ordering ARP bolts in a shorter size for it. I don't like the allen head bolts that it came with, also ARP Dseries flywheel bolts.
Old Oct 28, 2013 | 02:41 PM
boostlsveg's Avatar
r u saying u used d series or ur gonna switch?
Old Oct 28, 2013 | 03:53 PM
rudebwoy's Avatar
the flywheel bolts are from Dseries, I ordered a set of ARP Bseries bolts and they bottomed out before they got tight so I called CC Clutch and they told me I have to use Dseries bolt.
Old Oct 28, 2013 | 06:04 PM
boostlsveg's Avatar
Hmm I used the bolts that came with the kit n they didn't bottom out that I noticed.. I'll have to pull the tranny back off n double check it. Were u able to order 8 d series ones from arp?
Old Oct 29, 2013 | 02:49 AM
wantboost's Avatar
Who is Mr Robot?
The flywheel bolts that come with the kit from CC are D series... It's the guys that buy them secondhand/used that have to source the D series bolts themselves after finding out the B series bolts are too long.
It all has to do with the thickness of the flywheel at the hub, they made it a little thinner to save weight as well as some other technical things IIRC.
We've run CC twins in everything from professional drift cars (Virjin Jorj R32 sr20ve, z32 trans, etc) to weekend drift cars, high hp daily drivers, civics, supras, etc. Everyone was happy with the clutch.
A lot of people couldn't get used to the chatter at first, but because the floater/pp isn't strapped the floater moves a round a bit with the clutch pedal in
Old Oct 29, 2013 | 03:39 AM
Tony the Tiger's Avatar
Great info.. Nice to know that CC is also a good choice for clutches.
Old Oct 29, 2013 | 05:14 AM
boostlsveg's Avatar
oh ok cool man thanks for the info, that makes sense. I like the clutch for sure I actually ordered two when I got mine. One was for my buddy n I've driven his car numerous times n I like the engagement n everything on it.
SSJSubgeta
Oct 22, 2005 12:20 PM
Chiller
Apr 10, 2005 10:52 PM
doublejz
Oct 20, 2003 09:54 AM
mr_mbuna
Sep 12, 2002 02:36 AM
matht27
Jul 16, 2002 04:34 AM
