common wire to all injectors?
obd1
b18b stock injectors
the yellow wire in common with them all, is that power or ground? should the 4 of them alll be attached together and grounded?
if you use an obd-0 computer u will need a resistor box and run the left over wire to the battery. if u use an obd-1 computer you can just tie them together and put them to the battery. just make sure to fuse them either way you go. a 10 amp fuse will be fine.
c|rop3asy==[]
Sep 9, 2013 11:17 PM
niceprelude
Dec 24, 2008 07:13 PM
Tad
Audio / Security / Video
Nov 29, 2003 12:10 AM
