Cometic HG question.
Old May 30, 2006 | 08:07 AM
redlinetuning's Avatar
Default Cometic HG question.
I have a 81.5mm bore on my block. Cometic sent a 82mm .051" HG,.. is this right? I called and they said it's right, and I won't have any problems. I guess I just want some re-assurance from people who've used these hg's.
TIA.
btw... it's a b16a with cp 81.5mm 9.0:1 pistons (skirts are ceramic coated). ARP rod bolts on Eagle H-Beam ESP rods. ACL main and rod bearings. Clearanced and blueprinted short block.
balanced stock crank, rods, pistons, 12# ACT flywheel, Xtreme pressure plate.
Old May 30, 2006 | 08:23 AM
wickedEG's Avatar
Default Re: Cometic HG question. (redlinetuning)
it will work.
Old May 30, 2006 | 09:42 AM
Boostfed's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning &raquo;</TD></TR><TR><TD CLASS="quote">I have a 81.5mm bore on my block. Cometic sent a 82mm .051" HG,.. is this right? I called and they said it's right, and I won't have any problems. I guess I just want some re-assurance from people who've used these hg's.
TIA.
balanced stock crank, rods, pistons, 12# ACT flywheel, Xtreme pressure plate. </TD></TR></TABLE>
Stock headgaskets are already overbored to like 82mm, might be 81.5mm can't remember. The onlky thing is teh stock headgasket thickness is .29-.030" where as the one you have is .051" thickness so it will lower your compression slightly sir
Old May 30, 2006 | 02:26 PM
Default Re: Cometic HG question. (Boostfed.com)
Hey thanks guys. I'm new at this boost deal. This is also my first real deal motor too. I'll post up photos once i'm done with it. Still has some work to do yet.
gstrudler
May 3, 2009 11:04 AM
b16a4
Feb 8, 2007 08:48 AM
egvtec
Dec 12, 2005 03:49 PM
NSTY Z33
Aug 20, 2004 10:36 PM
GRIMEY.STREET.RACER
Jan 6, 2003 06:00 AM
