question about an lsd for a turbo'd b18a
Old Aug 7, 2002 | 07:06 AM
90teg's Avatar
Default question about an lsd for a turbo'd b18a
ok i searched but none of the posts anwsered my question. do i need to get a lsd for a turbo'd b18a? does the lsd bolt on, or do i need to change anything in the tranny. can anyone help?
Old Aug 7, 2002 | 09:32 AM
90teg's Avatar
Default Re: question about an lsd for a turbo'd b18a (90teg)
nobody???
Old Aug 7, 2002 | 09:37 AM
bruthaboost's Avatar
lsd's don't bolt on and aren't necessary, but will make driving much more pleasureable (sp?). The lsd replaces your stock differential. For the b18a/b it's pretty much drop in since the diff bearings are flat. The b18c and b16 trannies use a tappered bearing so they must check their preload and shim accordingly. You'll need the final drive gear off your stock diff to install onto your new lsd
look here:http://www.hondaautomotiveparts.com/...OHC%29+%282%29
hth
edit grammer
[Modified by bruthaboost, 10:38 AM 8/7/2002]
Old Aug 7, 2002 | 12:23 PM
90teg's Avatar
Default Re: question about an lsd for a turbo'd b18a (bruthaboost)
thanks that anwsered my question. that web site you gave me doesn't have any integra parts.
Dunc
Jun 16, 2005 12:47 AM
1slowassr
Apr 9, 2003 12:43 PM
Nameless RB26
Dec 9, 2002 08:53 AM
