Cold Weather...
Old Oct 11, 2001 | 04:00 PM
revhrdls's Avatar
Default Cold Weather...
Cold Weather=better boost experience right? Somewhere I read that you should let your car warm up before boosting happily,right? I can't remember why do
Anyways nowadays my BOV will not sound off since it's been colder why? also it's a type s the other day i took the the vacuum hose off it and put it back on. It goes on top port right? I can't remember how it goes
Old Oct 11, 2001 | 04:43 PM
mercury's Avatar
New User
Default Re: Cold Weather... (revhrdls)
Every car should be at its normal warm operating temperature before you get on it, but especially turbo cars. When cold, the pistons virtually rattle around inside of the block, so if you put high cylinder pressures into there, you're going to blow your piston rings. The engine oil also needs to be at the warm temperature before it starts lubricating well.
hondatuner020
Feb 24, 2011 08:58 PM
BobbyRodriguez
Nov 16, 2010 08:03 PM
aznboi_106
Aug 10, 2010 10:07 AM
Mikes2000civicsi
Jan 28, 2007 07:08 PM
GTEater
Nov 29, 2001 05:38 PM
