Cold start problems
Old Dec 20, 2004 | 12:23 PM
Maxime's Avatar
Default Cold start problems
So it was very cold this morning. It was -19F (-38 with windchill). My car barely started. It was running very rough and it stalled a few times.
I'm thinking it's having a hard time to start because of the colder sparkplugs I'm running in the car. Right now I have BKR7E. Should I put stock specs sark plugs for the winter?
Old Dec 20, 2004 | 02:07 PM
m R g S r's Avatar
Default Re: Cold start problems (Maxime)
shiit. . . thats cold.
Make sure your car is rich enough, I imagine it would lean out alot with those kind of temps. .
Sorry I can't help with the problem. Is your battery up to date?
Old Dec 20, 2004 | 03:18 PM
IN VTEC's Avatar
Fuel atomization is probably really poor. Maybe you could try using a block heater and running the intake manifold, throttle body, and IACV coolant lines (if you have those blocked or circumvented).
Old Dec 21, 2004 | 11:05 AM
Maxime's Avatar
Default Re: Cold start problems (IN VTEC)
My wideband is starting to act strange too.
It's reading LEAN. While the car is running rich.
I don't maybe the problem is my injectors. Maybe they dont like the cold weather?
Old Dec 21, 2004 | 01:12 PM
Civicman86's Avatar
holy **** thats cold. Move your *** down to florida or something.
What was temps were the car tuned at? The density of 70 degree air and -20 degree air could maybe cause the leaness. I dont know if it would be that great though.
Old Dec 21, 2004 | 01:28 PM
IN VTEC's Avatar
The wideband can't detect the fuel that isn't in vapor form. If it's still in liquid form, it'll just condensate on the exhaust tubing wall and/or pool at the bottom.
dcivic91
May 8, 2020 06:22 PM
the.hamburglar
May 2, 2006 09:27 AM
92HB_HB
Mar 8, 2005 09:02 PM
theneil
Jul 5, 2003 09:44 AM
djkermie
Oct 27, 2002 01:49 PM
