code 9 cel help!!!!
Old Nov 16, 2006 | 04:54 PM
crazi92hb's Avatar
Default code 9 cel help!!!!
OK AFTER 2 WEEKS OF PLAYING WITH MY BOOSTED D16Z6 PROJECT I CANT GET THIS CODE 9 TO GO AWAY. I NEED TO KNOW THE EXACT COLORS FOR THE WIRING ON AN OBD1 DISTRIBUTOR. THIS DISTR. WORKS ON MY COUPE BUT THROWS A CEL ON MY HATCH.
Old Nov 16, 2006 | 08:31 PM
xenocron's Avatar
Default Re: code 9 cel help!!!! (crazi92hb)
see a helms
check for resistance on that circuit
then check continuity in the wires
most times i see a code 9 isnt improperly shielded wires or loose connections at the ECU
Old Nov 16, 2006 | 08:33 PM
Absubtle's Avatar
Did you get this thing fixed or not? I can give you the info.. just wondering if you need it.
Absubtle
CO
Old Nov 17, 2006 | 11:00 PM
94 delsol's Avatar
Default Re: code 9 cel help!!!! (Absubtle)
im getting the same code on my car any help would be appreciated
Old Nov 18, 2006 | 09:40 AM
crazi92hb's Avatar
i was lookin at the car but i need to know what wire the cyp sensor is becuase i have no clue i placed a 3rd workin distributor on it and the same thing happened but when it goes back on the coupe its fine.
Old Nov 18, 2006 | 10:24 AM
sgtroseberry's Avatar
orange, couldn't tell if any other colors where on there, its the cylinder #1 position sensor, if its not bad wireing it time for a new dizzy hope this helps
Old Nov 22, 2006 | 05:20 PM
crazi92hb's Avatar
Default Re: code 9 cel help!!!! (sgtroseberry)
its the dash harness i ran the wire strait from the distributor to the ecu and the code went away thanx
tygerEF2
Jul 12, 2011 03:27 PM
<3_My_EGG
Sep 23, 2009 04:25 PM
crxnonvtec
Aug 28, 2009 11:13 AM
nonvteclude
Dec 29, 2006 09:22 AM
