code 9 cel help!!!!
OK AFTER 2 WEEKS OF PLAYING WITH MY BOOSTED D16Z6 PROJECT I CANT GET THIS CODE 9 TO GO AWAY. I NEED TO KNOW THE EXACT COLORS FOR THE WIRING ON AN OBD1 DISTRIBUTOR. THIS DISTR. WORKS ON MY COUPE BUT THROWS A CEL ON MY HATCH.
see a helms
check for resistance on that circuit
then check continuity in the wires
most times i see a code 9 isnt improperly shielded wires or loose connections at the ECU
i was lookin at the car but i need to know what wire the cyp sensor is becuase i have no clue i placed a 3rd workin distributor on it and the same thing happened but when it goes back on the coupe its fine.
orange, couldn't tell if any other colors where on there, its the cylinder #1 position sensor, if its not bad wireing it time for a new dizzy
hope this helps
hope this helps
