Code 1 after install - Checked O2 but it's fine..... What's Wrong???
Old Aug 23, 2003 | 11:19 AM
VTECVillain's Avatar
Default Code 1 after install - Checked O2 but it's fine..... What's Wrong???
I have a 99 B18C1 in my 92 VX and recently installed a JRSC complete with all original JR parts including the FMU. As soon as I turned the key over for the fuel pump to pressurize the CEL came on, I jumped the service connector and I'm throwing a Code 1. I checked the O2, even switched to another one but it's still throwing the code. I wondering if it has something to do with the fuel pressure - OEM FPR or the FMU possibly?
Keep in mind that the CEL came on before the car was even started and before the JRSC install the car has ran over 2 years with no CEL's. I followed the troubleshooting procedures for testing voltage and resistance with the O2 and the engine harness connector and it seems fine. Any suggestions?
Old Aug 23, 2003 | 12:39 PM
trbob16a's Avatar
Default Re: Code 1 after install - Checked O2 but it's fine..... What's Wrong??? (VTECVillain)
Are you sure it isn't code 10, intake air temperature sensor as a result of not re-installing it?
Old Aug 23, 2003 | 12:46 PM
VTEC-DA's Avatar
Default Re: Code 1 after install - Checked O2 but it's fine..... What's Wrong??? (trbob16a)
Sounds like it is a code 10, not a 1. Long blinks count as 10 and short blinks count as 1.
Old Aug 23, 2003 | 07:23 PM
Default Re: Code 1 after install - Checked O2 but it's fine..... What's Wrong??? (VTEC-DA)
It does flash one long blink so 10 it must be. That would make sense if it is the Air intake temp considering that the RED/YEL wire is the one that is cut and wired to the Fuel enrichment solenoid. But I don't think that the wiring is the problem. I have an LHT performance manifold which has the water cores inside. The air intake temp sensor hits the core so I modded an old one by grinding some of the tip off which exposed the small wires inside. Looks like I'll need to make a spacer that will push the sensor out far enough for clearance or maybe use one in my intake tube from a 96+ Civic.
jdmdreamz414
Jul 22, 2011 04:20 PM
crx_si-r
Feb 17, 2010 05:16 PM
DarkBB4
Aug 27, 2005 09:31 AM
VTECVillain
Aug 23, 2003 08:49 PM
