Clutchnet stage II install!!
Old Mar 2, 2002 | 12:37 PM
jamal-188's Avatar
Default Clutchnet stage II install!!
I"m finally going to putting on my clutchnet stage II and clutchmaster aluminum flywheel on tuesday. I can't remember what Ben told me on break in, 300 or 500 miles, and what RPM should I shift at while breaking in, like 3k or lower? My acura service manual says to replace a few gaskets like on the exhaust manifold and such but is it really necessary?
Thanks guys!!
Old Mar 2, 2002 | 12:50 PM
Anthony K's Avatar
New User
Default Re: Clutchnet stage II install!! (jamal-188)
Thanks guys!!
Do 500 miles. It may chatter a little at first, but as you get closer to 500 miles or so, it breaks in nicely. Just drive normally...no redline shifts. I don't think you have to replace the exhaust gaskets...just wait till you have to.
This might get tossed into the Newbie Questions.
Old Mar 2, 2002 | 02:50 PM
D-SPEED's Avatar
Default Re: Clutchnet stage II install!! (Anthony K)
just drive like a normal person for 500 miles. My brother and I installed the exact same setup on his integra. It chattered a bunch at first, but its alot better now. I dont remember if we even took the header off... I think we skipped that, so no new gaskets. There is plenty of steps the helms suggests to do, that you can get away without doing.
Old Mar 2, 2002 | 03:43 PM
GSRrR's Avatar
Default Re: Clutchnet stage II install!! (D-SPEED)
When I first had my car back after the clutch install, it was very hard to drive. It chattered alot and would shake my whole car. It gets better after you drive for a couple hundred of miles. Just shift a little bit lower then normal and when speeding up like on a highway or freeway, just take your time. I was driving like a grandma for the first couple hundred of miles.
Old Mar 2, 2002 | 05:29 PM
DragII's Avatar
25 Year Member
Default Re: Clutchnet stage II install!! (GSRrR)
mine has not chattered a bit since I installed it....infact...it never chattered at all.
great clutch though...I love it.
linx
May 4, 2007 09:58 AM
10000rpm
Oct 30, 2004 04:27 PM
flat-blk-HB
25
Jun 2, 2004 04:00 PM
superls92
Feb 7, 2003 07:11 AM
Splat
Oct 14, 2002 12:34 PM
