Clutchmasters stage 3 carbon kevlar disc, how much whp/tq can it run?
i have a clutch setup that looks like this as of now
ACT prolite flywheel
Act xtreme pressure plate
Arp flywheel bolts
Arp Clutch bolts
how much whp/tq will this kinda setup hold. i dont want a puck clutch as i want power and driveability.
anyone running this clutch
Arp flywheel bolts
Arp Clutch bolts
Re: Clutchmasters stage 3 carbon kevlar disc, how much whp/tq can it run? (b18sihatch)
It a really nice daily driving clutch, i make 280wtq and it held up fine. It drive like a stock clutch im my opinion.
I would also like to know if anyone have went into the 300+ wtq with this clutch, my next set-up should make around 320+wtq so im thinking of going with a stage 5 but am interest to know how much the stage 3 can hold up to.
i ran my kevlar and loved it for the street w/ minor power n/a...a freind runs it in his f22/h22 vtec motor and its holdin up great...my only prob w/ kevlqar is that onces its heated up it tends to slip...after about 6 passes i had to let it cool down or else it would grab at all....so i eventually step up to a ceramic unsprung disk before i boosted....and has buged an inch since i put it in...its a lil tricky to dd but you get the hang of it....
but i loved my kevalr disk when i had it...**** ran great and felt like stock!
Re: (b18sihatch)
im running it in my car .I put it in when i was running my NA k20 setup and didnt think i was going to run as much boost. I havent run it at the track with more than 350whp but will put it to the test soon on 450whp & 318 Ft lbs
Re: (na200whp)
im not looking to track my car however i would like somewhere in the range of 350-450whp, im not sure wat kinda torque that may bring but i would really hate to have to go to a puck clutch, kevlar is gentle on the presure plate and flywheel. also good on the tranny. if i can hit 350-400whp with it with no problems iwould be happy
Re: (na200whp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by na200whp »</TD></TR><TR><TD CLASS="quote">im running it in my car .I put it in when i was running my NA k20 setup and didnt think i was going to run as much boost. I havent run it at the track with more than 350whp but will put it to the test soon on 450whp & 318 Ft lbs
Hmm 320 tq huh? does it show any sign of slipping? if it is able to hold that much power then i dont see the need of me upgrading to stage 5
I have a stage three and haven;t had any problems except it doesn;t want to disengage above 9,000 rpms . Other than that it has held up grat on my ls.vtec running 14psi throught a t3/04e50 trim
Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">it'll hold a decent ammount of power till the springs fall out of it, and the hotter it gets the worse it works</TD></TR></TABLE>
Around how much? until it start slipping
Re: (b18sihatch)
I have tuned many cars 400+ with CM3 clutch's.
I run a CM4 in my ITR , it slipped a little the other day with a quick 4th to 5th shift but it's in been in there for over a year.
I'm making way more than it was designed for .
just make sure the flywheel is turned and steped according the the clutch specs and you will be find, people who have the problems with clutches most of the time don;t ge the flywheel turned properly
Re: (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">I have tuned many cars 400+ with CM3 clutch's.
I'm making way more than it was designed for .</TD></TR></TABLE>
Hmm how much torque were you making?
Re: (b18sihatch)
The pressure plate the fx300 came with was just a heavy duty pressure plate, however i had the act xtreme pressure plate from another setup (new) so i got all that together
which leads me to believe if holding capacity is rated at 110% over stock with a hd pp then it should be more holding capacity over 110% being its a xtreme pressure plate.
does that sound right?
also would you guys say these clutches are underrated? 110% over stock and making 450whp and 320tq is much more than 110%
Re: (b18sihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18sihatch »</TD></TR><TR><TD CLASS="quote">also would you guys say these clutches are underrated?</TD></TR></TABLE>
Yes I do. But it all depends on the amount of tq made.
i have the CM stage three and went to tune last week. didnt get one good run in bc every time full bost hit the bitch slipped. I ordered (and just recieved) a stage 4 6-puck sprung Competition clutch that should hold up just fine.
