Clutchmasters FX500
Old Jun 16, 2010 | 08:13 AM
Importracer_001's Avatar
Default Clutchmasters FX500
Hi Guys,
I'm looking for a clutch that can hold 600whp. Do you think a CM FX500 will be able to hold 600 whp or lets day 140MPH in a 2500 lbs integra?
What do you think about the sintered iron disk on a stock tranny?
Old Jun 16, 2010 | 08:17 AM
tony1's Avatar
Default Re: Clutchmasters FX500
Holding 600whp on the dyno wouldn't be a problem. Racing a 2500lb car on slicks with 600whp probably would. If it did work, I don't think you'd get much life out of the clutch on the track.
Old Jun 16, 2010 | 11:19 PM
t66crx's Avatar
the FX500 with the power plus 2 pressure plate will hold up. its the double diaphram in it
Old Jun 17, 2010 | 02:01 PM
Turbo-LS's Avatar
the sintered disc cant be street drivien. its designed for in and out only. with the amount of slipping required for daily driving it puts alot of heat into the clutch and the sintered disc breaks apart
Old Jun 21, 2010 | 07:58 AM
mrx's Avatar
mrx
i've driven this clutch for quite some time on the street. It's possible and it will not fall apart, but it will eat up flywheels and from compfort point of view it is VERY undrivable in normal traffic. I would not recomment it for any street application.
I just had to use it because CM sended me the wrong clutch (wanted a stage4) and i had a broken clutch so i had to use it to keep my car running.
Old Jun 21, 2010 | 09:48 AM
jetspeedz's Avatar
Get the FX400 with 4 puck which will easily handle that HP and on the street it's better then OEM. love this clutch. Also get the clutchmaster flywheel with the steel outer teeth and you will never look at anything else again. I also hope you have some good axles
slowsol95
Apr 18, 2007 04:56 PM
chunky
16
Feb 25, 2007 09:40 AM
Aloha04MSM
Feb 14, 2006 03:26 AM
B16A1-EF9
Feb 13, 2005 10:59 AM
OPTIMUS
12
Apr 22, 2002 11:33 AM
