Clutch Suggestions for boosting
Old Jul 17, 2012 | 12:25 PM
SiRCiviC94's Avatar
Default Clutch Suggestions for boosting
well well the ebay cheap simple build ran 100's of passes and the clutch was overheated in 5th doing several 5th gear pulls. my track time is also affected and was never at max potential anyway.
Stock gremlin B16a....T3T4 ebay turbo on 7 soon to be 10 PSI. LSD B16 tranny.
I want to know what the racers suggest. the car has ocasional work/daily use....and will probably see 400HP at some point but is mainly for drag racing at 200torque or less (1.6)...for now I do have a gsr for later.
from my research a stage 3 or 4 XTD or Yonaka would do the trick, but I can get deals on ACT, Excedy, competetion. I will not use a bully.
suggestions? I need to bang into the 12's, my clutch, using chrome, and a B16 trans is limiting me right now. we knock off one thing at a time and practice driving along the way
thanks!
key points:
what clutch, should i upgrade the flywheel or resurface the stock one? this clutch/flywheel is over 10 years old trans shifts really well I do not want to lose the smooth shifts i have right now
Old Jul 17, 2012 | 01:22 PM
blackeg's Avatar
Default Re: Clutch Suggestions for boosting
ive become a big fan of the comp clutch. ive got the stage 5 in my car, and one of my friends has a stage 4 in his boosted b16. ive owned exedy and act clutches in the past and the comp by far takes the cake
Old Jul 17, 2012 | 01:29 PM
bluedragon's Avatar
I have a center force stage 3 had couple years love it had same set up u have and no w have a bigger rd build still holds nice
Old Jul 17, 2012 | 04:09 PM
SiRCiviC94's Avatar
I was leaning toward a competition...does the logevity of the clutch plate change with a higher stage? & would an aftermarket flywheel benefit my time over stock?
competetion stage 4? hmmm
Old Jul 17, 2012 | 05:22 PM
EsotericImage's Avatar
Retired Moderator
Ive only used ACT so I cant comment on any other brand..
but I have the 4 puck unsprung for 3 years now and still holding up to 241lbs/tq
Old Jul 17, 2012 | 05:32 PM
LightningTeg's Avatar
Community Builder
Running ACTs in both my cars. Never an issue
Old Jul 17, 2012 | 05:42 PM
SiRCiviC94's Avatar
image whats your car running this year at the track? 241tq now wow I havent been following its a stock gsr running high boost now ? im going to have to continue tuning once the clutch goes in.
Old Jul 17, 2012 | 05:47 PM
Retired Moderator
best was 1.93 60" @ 12.6 on slicks
Old Jul 17, 2012 | 05:53 PM
blackeg's Avatar
i used to go through 2 act disks a year, or about every 5000-6000 miles. when id replace them there would be fingernail size chunks of the friction material missing. my power numbers are in my sig, its nothing out of the ordinary
Old Jul 17, 2012 | 06:02 PM
Retired Moderator
Mine was mostly DD with a strip pass here and there..
Old Jul 17, 2012 | 08:51 PM
turbohatch96y7's Avatar
Do you have to keep your rpms high to get it out of first with your stage 5?
How long is the break in times ?
Old Jul 17, 2012 | 09:51 PM
rico892002's Avatar
ACT FTW...i had a comp clutch for 3k miles it failed and the company didnt event want to fix or warranty it out..never again
Old Jul 17, 2012 | 10:01 PM
justYncredible's Avatar
It's wU to the sOLdiEr!
i have had a ACT in my da and a ACT in my dc2
during my rebuild i went with CC
i never had a problem with either. sorry to hear about your mishap rico
my CC has been performing much better after i got tuned with my turbo.
Old Jul 17, 2012 | 10:08 PM
rico892002's Avatar
its all good..i really like the feel of the act xtream PP with 6puck disc..would love to switch to a twin disc soon
Old Jul 18, 2012 | 12:52 AM
wantboost's Avatar
Who is Mr Robot?
Old Jul 18, 2012 | 04:12 AM
blackeg's Avatar
na not really. its no different than any other 6 puck that ive driven in that regard. ive noticed though that problems getting in an out of gear and such are probably the pressure plate and not necessarily the disk itself.
for break in i just didnt kick its *** for the first few hundred miles. i kept the boost a little lower and didnt launch or bang gears, but i was still driving it pretty good. comp recommended a long break in and i think act recommended a shorter break in. take it as you will, but i really think its just about lapping or getting the friction material on the surfaces of the flywheel and pressure plate evenly without any excess heat or warpage
Old Jul 19, 2012 | 04:24 PM
SiRCiviC94's Avatar
still undecided, my torque shouldnt burn any clutch up for atleast 50k how long do they last?
Old Jul 20, 2012 | 11:09 AM
shawty22's Avatar
I had a stage 5 in for about 2-3k miles, it wasnt to stiff on the pedal. Never NOTICEABLEY slipped, but due to having to pull the motor out due to bearing issues, there were three pretty big chunks missing out of it. Buddy pulled his off the same time as i did and it was the exact same results. We made a little more than 400lbs of torque, but CC says they are good for 450ft. I got a 6 puck (heard of more people having luck with those) and had everything resurfaced to see if that helps out any. If not, time to never use CC again...
Old Jul 20, 2012 | 04:05 PM
wantboost's Avatar
Who is Mr Robot?
when you're near the limits of a clutch like that and drive it hard, things happen... its almost time for a twin plate for you
Old Jul 21, 2012 | 08:13 PM
SiRCiviC94's Avatar
excedy doesnt come into this? what about the cheapys a stage 3 yonaka lol it would get me by?
http://www.ebay.com/itm/Yonaka-Heavy...0c5a99&vxp=mtr
Old Jul 21, 2012 | 08:25 PM
Retired Moderator
reliable>cheap
Old Jul 30, 2012 | 06:36 PM
SiRCiviC94's Avatar
6 puck ACT for $500 plus $$$ for install. stupid clutch.
I saw two different 6 puck disks, one rated at 410 and one at 3 something. same PN on ebay too
Old Aug 12, 2012 | 02:21 PM
SiRCiviC94's Avatar
Xtss is the choice... Hope it lasts
Old Aug 12, 2012 | 03:04 PM
Stop being a girl and install the clutch yourself.
Bam! Instant savings
Old Aug 12, 2012 | 03:11 PM
FEDONV8's Avatar
Its easy im running a stage4 competition clutch in my hatch and it just fine
