CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe
I want a CRX tattoed on my butt
So my hatches clutch is sliping I believe.
I noticed it today in 5th when I kinda punched it on the freeway and the rpms rose a good 150 and the car didnt really accelerate, didnt think much of it
Then later I tried to do a ripper from a stop light, shift into second was alright, not much of a pause between catching up to the motor. But then on the shift to 3rd it must of stayed there for atleast a second before the rpms came back down.
Im curious if adjusting the cable somehow can fix this?
Also because this is an older b16 I believe (obd0 pr3) cable trans, I dont know what version of the b16 clutch I can buy or if there all the same, or if the GSR clutches and such will work
Need some help
Need some help
Mr. Badwrench
Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (PINKS)
the only way adjusting will fix, is if it is too tight, but if it is gone, no ammount of adjusting will fix.
i cant remember what cable trans is the same as the newer b series.. i think if i remember, the 92 and up cables are the same splines as the newer b series.
Cable b16's have there own clutches.
U can use any Bseries PP and flywheel however.
Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (93supercoupe)
Try thi thread I started, no replies so I guess most of the US guys don't run a cable box in the B16?
Anyway, will give you the part number of the clutch I'm about to drop in my JDM B16 Cable.
https://honda-tech.com/zerothread?id=1949088
Eddie
Eddie
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93supercoupe »</TD></TR><TR><TD CLASS="quote">Cable b16's have there own clutches.
U can use any Bseries PP and flywheel however.</TD></TR></TABLE>
no they dont.
i am 100% sure there are 2 different input shafts. untill some year, then they are the same as the hydro. i just cant remember what trans has what input shaft.
no they dont.
Mr. Badwrench
Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (EddieCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EddieCRX »</TD></TR><TR><TD CLASS="quote">Cable 25.4
Hydro 25.9
what cable trannies?
integra?
the civic b cables are different.
OR SO I HAVE BEEN TOLD.
i was always told, the civic crx b trannies are the same as the tegs til 91. then from 92 on they are the same as the hydro.
Hydro 25.9
integra?
90-91 LS and JDM cable trans 1" X24 tooth aka "small spline"
92+ LS/GSR cable and all hydro trans 1.0625" X24 tooth aka "big spline"
The OP can order a 90-91 LS clutch and have a good time with it. I, however, would ditch the JDM cable box as they are usually crusty and old these days.
Re: (Joseph Davis)
OK SO I can buy a 90-91 LS clutch /gsr / b16 and it will be fine?
I dont get what you guys mean by the "cable" boxes though
Re: (Joseph Davis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Joseph Davis »</TD></TR><TR><TD CLASS="quote">90-91 LS and JDM cable trans 1" X24 tooth aka "small spline"
The OP can order a 90-91 LS clutch and have a good time with it. I, however, would ditch the JDM cable box as they are usually crusty and old these days.</TD></TR></TABLE>
i know this to be true. sorry i deleted the pics a long time ago
https://honda-tech.com/zerothread?id=1405376
Re: (abnaasefmb)
Theres some cheap clutches on ebay if youre looking for a factory replacement, like $80ish from a company called seco I blieve
http://cgi.ebay.ca/ws/eBayISAP...h=005
Or they have a stage 3 (285ft/lbs) for like $135, called Gripforce or something
Re: CLUTCH SLIPPING!! All b16 Clutches the same? Cable Adjust To Fix Maybe (W O T)
Try these people
http://cgi.ebay.com/ebaymotors...54643
They are based in the US so it should be easy for you, little harder for us Europe folk
This is the clucth kit for the cable B16 box NOT hydro,,,,,,,
They sell other kits, I think a 6 puck will be far too much for NASP, I suggest not to go for the heavy duty cover plate, it's heavy on a cable box, takes some getting used too.
Location: That's the wrong tone... I'm Skunk2 certified.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by W O T »</TD></TR><TR><TD CLASS="quote">Stage 3 on an n/a b16?</TD></TR></TABLE>
dude it's a $70 clutch! NEW!
yeah, i'd trust that.
PINKS
04-17-2007 06:43 PM
PINKS
04-17-2007 02:40 AM
PINKS
04-16-2007 12:07 PM
InJ3cted
05-24-2005 02:16 PM
blackmagicCRX
10-25-2004 11:59 AM
