clutch problems
Old Aug 21, 2006 | 06:16 PM
95civicgsr's Avatar
Default clutch problems
hey guys i have a couple of questions for you. i have been having clutch problems since making two passes at the track. the tranny has been chattering alot and i thought it was the throw out bearing. we removed the tranny today and the pressure plate was in two pieces. the disk looked ok but all three of the (ill use rivets for lack of a better word)rivets that hold it together have sheared off. when we removed the tranny and began to remove the pressure plate the inner part fell out. i have never seen anything like this before so i am not sure if this is something alot of people have had problems with. well here are a few pics sorry for the quality. it is an act unsprung 6 puck with less than 300 miles and386hp 255 ft lbs tq.
thanks for looking.
Old Aug 21, 2006 | 06:28 PM
B18C Turbo's Avatar
my friend put his on backwards and the same thing happened
Old Aug 21, 2006 | 06:38 PM
95civicgsr's Avatar
Default Re: (B18C Turbo)
it was installed correctly. how long did it take for that to happen to his?
Old Aug 22, 2006 | 05:01 PM
95dc2teg's Avatar
Default Re: (95civicgsr)
isnt the break in period for those clutches like 500 miles? Maybe thats why it blew apart.
Old Aug 22, 2006 | 05:05 PM
Nonsteezy's Avatar
Default Re: (95dc2teg)
theres no break in periods on puck discs, and u cant install it incorrectly anyways, i think it was just a bad pressure plate.
Old Aug 22, 2006 | 05:20 PM
95civicgsr's Avatar
Default Re: (Nonsteezy)
what nonsteezy said!!!
Old Aug 22, 2006 | 05:53 PM
JDMlyfestyle's Avatar
same thing happened twice to my friends clutch in his VW corrado. first time the pressure plate fell apart. after we got a replacement clutch it didnt even make it 30 miles in the break in period and the Buttons on the clutch came off and we thought we blew the tranny because the button wedged its self between the pressure plate/ Throw out bearing and it welded the clutch/plate/disk together and was stuck in gear.
never been a fan of ACT clutch since then
Old Aug 25, 2006 | 01:49 PM
95civicgsr's Avatar
well now i have another ?. what kind of damage could have been done to the motor due to the pp coming apart like this? took the flywheel off and it wasnt pretty . ill try to post pics later.
Old Aug 25, 2006 | 11:51 PM
95civicgsr's Avatar
ttt
krunkchris
Mar 17, 2009 10:13 AM
Stoich EG2
Mar 26, 2005 06:07 AM
nocturnaldragon
Apr 30, 2004 08:18 PM
Jowee
Jan 10, 2004 05:19 PM
HX_Guy
Aug 29, 2001 09:09 AM
